The track is unable to read 85%
500GB(976773168) only read to 170773168 sector
how can slave it ?
7200.11 st3500320AS read error UNC
Re: 7200.11 st3500320AS read error UNC
robert258 wrote:The track is unable to read 85%
how can slave it ?
this is because u or somebody did a translator regeneration that did not run perfectly and the new user slip list is missing some sectors that the old one had.
Utility current version cannot handle it.
I can if U don't mind sending it.
pepe
I am in Asia, you can provide the solution?
Pepe wrote:I can if U don't mind sending it.
first u have to check how many extra sectors are right before the point it gets unreadable, then add them to the user slip list.
pepe
pepe
This is interesting, not seen this fault before!
My very first 7200.11 had this problem, so the standard solution the utility provides was only partial, I had to dig more deeply and develop some things to solve this problem.
pepe
pepe
Pepe wrote:My very first 7200.11 had this problem, so the standard solution the utility provides was only partial, I had to dig more deeply and develop some things to solve this problem.
pepe
oh ! Thank you for your help.
