7200.11 st3500320AS read error UNC
robert258
Postby robert258 » 02.02.09, 08:11
The track is unable to read 85%
500GB(976773168) only read to 170773168 sector
how can slave it ?
Pepe
Re: 7200.11 st3500320AS read error UNC
Postby Pepe » 03.02.09, 01:18
robert258 wrote:The track is unable to read 85%
how can slave it ?
this is because u or somebody did a translator regeneration that did not run perfectly and the new user slip list is missing some sectors that the old one had.
Utility current version cannot handle it.
I can if U don't mind sending it.
pepe
robert258
Postby robert258 » 07.02.09, 03:59
I am in Asia, you can provide the solution?
Pepe wrote:I can if U don't mind sending it.
Pepe
Postby Pepe » 07.02.09, 19:17
first u have to check how many extra sectors are right before the point it gets unreadable, then add them to the user slip list.
pepe
Postby AJ2008 » 10.02.09, 10:49
This is interesting, not seen this fault before! :)
Pepe
Postby Pepe » 11.02.09, 00:03
My very first 7200.11 had this problem, so the standard solution the utility provides was only partial, I had to dig more deeply and develop some things to solve this problem.
pepe
robert258
Postby robert258 » 16.02.09, 17:59
Pepe wrote:My very first 7200.11 had this problem, so the standard solution the utility provides was only partial, I had to dig more deeply and develop some things to solve this problem.
pepe
oh ! Thank you for your help.
