We have a drive that outputs to terminal as follows:
Interface task reset
4096k x 16 SDRAM
TONKA2 - 1_Disk M-31 02-06-06 14:21
Spin Ready
(P)SATA Reset
Failed sys sect. write
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Unable To Load Overlay 01|000A
T>
PCB is good, heads are good. How can we fix firmware to access data?
ST3808110AS Unable To Load Overlay 01|000A
Re: ST3808110AS Unable To Load Overlay 01|000A
T>
This drive has problem with writing to surface. Heads can read but cannot write nessecary data when the drive starts up.
To recover the data you have to find a donor drive and do a head swap. It is possible that heads from one donor will not fit.
Developer advised to try several donors for this case.
There is several problem caused such case. But Mostly is addaptive data got problem SO HD Locked for writing to SA. Sometime HS from terminal can help you to cover addaptive problem...
steven wrote:There is several problem caused such case. But Mostly is addaptive data got problem SO HD Locked for writing to SA. Sometime HS from terminal can help you to cover addaptive problem...
Can you give more information on this?
Im am also looking for this advice
-BR-
-BR-
HS just can help in some case only and not ALL case. it depend.
See this from ACE web for lates update
Seagate
* New possibilities of utility and DE interaction are appended. Now the following actions are available:
1. the second variant of solving "pending problem"
2. SysSect writing blocking while HDD working
3. modification LBA->PCHS through ATA interface
4. soling the problem of impossibility of HDD launching in ATA mode as a result of impossibility of overlay loading ovl1
is this mean can solve the problem of Unable to load overlay 01
Hope sonner this can be covered as well. If we need to change several head set. it is not a good idea caused we face our lucky in this case.
BTW a question to acelab.. When the update will be released, is there got some problem with the beta test. it take very long time for this update ??? Never like this before...
thanks
Seagate
thanks
I never saw an announced update take that much time to be released
Hope their are packing the update with a lot of new utilities
Wondering if someone from ACE can give us an ETA?
-BR-
-BR-
http://www.acelab.eu.com/pc3000.udma.ver4.2x.php
here it is.. posted in first of July 2009
dis u see it ???
dis u see it ???
yes, i saw that a long time ago
i just want to know when we users are going to see it in our update boxes
-BR-
-BR-
mekaniq wrote:PCB is good, heads are good. How can we fix firmware to access data?
Solution: Just install the new version of PC3KUDMA.
I had a drive with this problem after a platterswap. I tried several sets with heads with no luck. All heads was working 100% when they was put back in their home drives.
Run DE and just select the fix for Ovl1
Good work AceLab!!
