Is there a way of unlocking PW protected MHVxxAH drives?
When running the unlock password wizard I get a message saying SU us not writable an that I should use terminal to remove the password - I dont know the jumper settings for the adapter.. Does anyone know this info ?
Mike
MHV2080AH Password
Re: MHV2080AH Password
Mike
That's a very good question I have the same problem. On the previous PC3K I used the Hitachi jumper settings successfully but for the UDMA this is not the solution. Did you resolve this?
Derek
Derek
You should have a MHV terminal adaptor with your PC3000 for removal of password, it attaches to PCB and should be a simple procedure, unless I am misunderstanding the problem.
- Mike_Montgomery
I ordered the Terminal adapter from Acelab as my UDMA and all is well
THanks,
Mike
THanks,
Mike
and now can be done to MHW and MHX
I have PC3K UDMA and the new Fujitsu terminal connector. Though there was no documentation regarding the terminal connector to PCB connections, I tried and it it worked swiftly with MHV2080BH
Regards,
Mathew
Regards,
Mathew
If you havent adapter you can use seagate sata adapter and 2 goldpins. (TX and RX is enough). just look at pcb there are 4 holes for connector, put these goldpins there and look on seagate sata adapter where TX RX traces go. This is all you need. Tommorow ill take a picture for adapter placement.
Here it is
Here it is
- Attachments
- on this photo its MHW2160BJ
- terminal_fujitsu.jpg (68.39 KiB) Viewed 23073 times
Who does not know anything, must believe in everything
Thanks for the trick
Thinking outside the box, I like this
- avenger-fr
An other way (for MHV2100AH IDE)
- cuumaytinh
it not work . I'm try and wait 60 min . nothing change
