MHV2080AH Password
Mike_Montgomery
MHV2080AH Password
Postby Mike_Montgomery » 16.01.09, 09:51
Is there a way of unlocking PW protected MHVxxAH drives?
When running the unlock password wizard I get a message saying SU us not writable an that I should use terminal to remove the password - I dont know the jumper settings for the adapter.. Does anyone know this info ?
Mike
STT
Re: MHV2080AH Password
Postby STT » 03.04.09, 12:47
Mike
That's a very good question I have the same problem. On the previous PC3K I used the Hitachi jumper settings successfully but for the UDMA this is not the solution. Did you resolve this?
Derek
Postby AJ2008 » 03.04.09, 12:52
You should have a MHV terminal adaptor with your PC3000 for removal of password, it attaches to PCB and should be a simple procedure, unless I am misunderstanding the problem.
Mike_Montgomery
Postby Mike_Montgomery » 03.04.09, 13:04
I ordered the Terminal adapter from Acelab as my UDMA and all is well :)
THanks,
Mike
steven
Postby steven » 04.04.09, 05:39
and now can be done to MHW and MHX
mvg
Postby mvg » 06.05.09, 10:35
I have PC3K UDMA and the new Fujitsu terminal connector. Though there was no documentation regarding the terminal connector to PCB connections, I tried and it it worked swiftly with MHV2080BH
Regards,
Mathew
aviko
Postby aviko » 10.05.09, 20:49
If you havent adapter you can use seagate sata adapter and 2 goldpins. (TX and RX is enough). just look at pcb there are 4 holes for connector, put these goldpins there and look on seagate sata adapter where TX RX traces go. This is all you need. Tommorow ill take a picture for adapter placement.
Here it is
on this photo its MHW2160BJ
Who does not know anything, must believe in everything
steven
Postby steven » 13.05.09, 04:31
Thanks for the trick
Postby AJ2008 » 25.05.09, 19:20
Thinking outside the box, I like this 8)
avenger-fr
Postby avenger-fr » 10.08.12, 12:12
An other way (for MHV2100AH IDE)
25140 013_crop.jpg (104.03 KiB) Viewed 22609 times
cuumaytinh
Postby cuumaytinh » 06.10.15, 20:47
it not work . I'm try and wait 60 min . nothing change
Return to “Fujitsu”
