HTS541 modules missing
prismakhas
Postby prismakhas » 11.04.08, 14:23
I have problem with 2.5 inch hdd with some damaged modules..
i want to rewrite the modules from DB..when i search or add i cant find any..
I have already update database with ibm/hitachi pcr file through update program..
please help me... thanks in advance..
dmarques
Postby dmarques » 14.04.08, 09:38
Probably your database doesn't have compatible modules.
What's the model of the drive and firmware?
prismakhas
Postby prismakhas » 14.04.08, 09:47
Can you check these after reading the module, what should i do?
Model : HTS541040G9AT00
Serial : MPB2A0X2C4 JMXF
Firmware : MB20A60A
Selected family......................... : HTS541
Model by ID............................. : HTS541040G9AT00
Loading the table of "open" modules................................... : Ok
Module RSVD Copy 0...................... : Ok
Module RSVD Copy 1...................... : Ok
Module RESF Copy 0...................... : Ok
Module RESF Copy 1...................... : Ok
Module RESF Copy F...................... : Ok
Module RAM0 Copy 0...................... : Ok
Module RAM0 Copy 1...................... : Ok
Module RAM0 Copy F...................... : Ok
Module OVR0 Copy 0...................... : Ok
Module OVR0 Copy 1...................... : Ok
Module OVR0 Copy F...................... : Ok
Module RESF(1) Copy 0................... : Ok
Module RESF(1) Copy 1................... : Ok
Module RESF(1) Copy F................... : Ok
Module PTCH Copy 0...................... : Ok
Module PTCH Copy 1...................... : Ok
Module PTCH Copy F...................... : Ok
Module CNS1 Copy 0...................... : Ok
Module CNS1 Copy 1...................... : Ok
Module CNS1 Copy F...................... : Ok
Module RWCN Copy 0...................... : Ok
Module RWCN Copy 1...................... : Ok
Module RWCN Copy F...................... : Ok
Module ZONE Copy 1...................... : Ok
Module ZONE Copy F...................... : Ok
Module PTRT Copy 0...................... : Ok
Module PTRT Copy 1...................... : Ok
Module PTRT Copy F...................... : Ok
Module SRVP Copy 1...................... : Ok
Module SRVP Copy F...................... : Ok
Module SRVM Copy 0...................... : Ok
Module SRVM Copy 1...................... : Ok
Module SRVM Copy F...................... : Ok
Module CHNL Copy 0...................... : Ok
Module CHNL Copy 1...................... : Ok
Module CHNL Copy F...................... : Ok
Module IDNT Copy 0...................... : Ok
Module IDNT Copy 1...................... : Ok
Module IDNT Copy F...................... : Ok
Module SN00 Copy 0...................... : Ok
Module SN00 Copy 1...................... : Ok
Module SN00 Copy F...................... : Ok
Module MISC Copy 0...................... : Ok
Module MISC Copy 1...................... : Ok
Module MISC Copy F...................... : Ok
Module ICES Copy 0...................... : Ok
Module ICES Copy 1...................... : Ok
Module ICES Copy F...................... : Ok
Module MLBA Copy 0...................... : Ok
Module MLBA Copy 1...................... : Ok
Module MLBA Copy F...................... : Ok
Module QMCN Copy 0...................... : Ok
Module QMCN Copy 1...................... : Ok
Module QMCN Copy F...................... : Ok
Module SMRT Copy 1...................... : Ok
Module SMRT Copy F...................... : Ok
Module PNID Copy 0...................... : Ok
Module PNID Copy 1...................... : Ok
Module PNID Copy F...................... : Ok
Module ABLP Copy 0...................... : Ok
Module ABLP Copy 1...................... : Ok
Module ABLP Copy F...................... : Ok
Module ABLD Copy 0...................... : Ok
Module ABLD Copy 1...................... : Ok
Module ABLD Copy F...................... : Ok
Module SSTL Copy 0...................... : Ok
Module SSTL Copy 1...................... : Ok
Module SSTL Copy F...................... : Ok
Module SERL Copy 0...................... : Ok
Module SERL Copy 1...................... : Ok
Module SERL Copy F...................... : Ok
Module SSST Copy 0...................... : Ok
Module SSST Copy 1...................... : Ok
Module SSST Copy F...................... : Ok
Module DCOT Copy 0...................... : Ok
Module DCOT Copy 1...................... : Ok
Module DCOT Copy F...................... : Ok
Module SRIF Copy 0...................... : Ok
Module SRIF Copy 1...................... : Ok
Module SRIF Copy F...................... : Ok
Module RDMT Copy 0...................... : Ok
Module RDMT Copy 1...................... : Ok
Module RDMT Copy F...................... : Ok
Module RELI Copy 0...................... : Ok
Module RELI Copy 1...................... : Ok
Module RELI Copy F...................... : Ok
Module PSHT Copy 0...................... : Ok
Module PSHT Copy 1...................... : Ok
Module PSHT Copy F...................... : Ok
Module OVR1 Copy 0...................... : Ok
Module OVR1 Copy 1...................... : Ok
Module SPRE Copy 0...................... : Ok
Module SPRE Copy 1...................... : Ok
Module PESD............................. : Ok
Module MFGP............................. : Ok
Module SRST............................. : Ok
Module FLOG............................. : Ok
Module DUMP............................. : Ok
Module ELG1............................. : Ok
Module ELG2............................. : Ok
Module EVLG............................. : Ok
Module PIDM............................. : Ok
Module AMPM............................. : Ok
Module HLR1............................. : Ok
Module HLR2............................. : Ok
Module DDD0............................. : Ok
Module MRDM............................. : Ok
Module DIAG............................. : Ok
Module WRT0............................. : Error
Module WRT1............................. : Error
Module @@01............................. : Error
Nova
Postby Nova » 14.04.08, 12:39
your modules look ok, the errors on some modules are normal.
prismakhas
Postby prismakhas » 15.04.08, 04:44
trying to find what kind of error that make that hdd undetectable... but couldnt find one..
if the modules are ok..why the hdd can't be detected..
please help me.. it is urgent..
dmarques
Postby dmarques » 15.04.08, 10:55
When you power the drive, enters ready?
When you enter utility, does it display any error message?
Can you acess the sectors of the drive?
Understanding this may give us some ideas how to help you.
prismakhas
Postby prismakhas » 15.04.08, 11:40
When POWER on, DRD and DSC show green light which means Drive ready.
and it show perfectly the model, serial , FW and capacity..
Set Max LBA............................. : No restriction
S.M.A.R.T............................... : Ok
and yes.. after that running express test..got a few yellow and pink blocks..
thats all..
what should i do next? Do i need to change FW ..
I have already done SA structure test..i could give rep file...
and the result is just like above..
what should i do?
dmarques
Postby dmarques » 16.04.08, 09:36
Well, first of all you don't need to use Universal Utility, you can use Hitachi utility.
Second, the drive seems to be OK.
What happens when you try to access data with Data Extractor?
prismakhas
Postby prismakhas » 17.04.08, 05:48
Yes, after run universal utility and perform express test..after that i have run hitachi utility and perform SA structure test.
and after that..i have run Data Extractor and make data copy..
After running Copy Data to Image Files..
Ihave explore directory tree..and could find root tree inside the hdd
Here the picture shown below
what should i do??
dmarques
Postby dmarques » 17.04.08, 09:19
You should image the drive to another drive with DE copy data option.
Then you can use r-studio software to check the imaged drive for the data.
prismakhas
Postby prismakhas » 17.04.08, 11:04
got other alternative or freeware software? R-studio is a shareware software.
Does Data extractor have a function like that? i have already did your instructions but r-studio demo cannot exceeds 64kb..
anyway, thanks in advance for your guidance..
dmarques
Postby dmarques » 17.04.08, 13:11
You can use DE and click right mouse button over NTFS partition and make Search for NTFS Structures.
prismakhas
Postby prismakhas » 18.04.08, 04:57
it's done now..
using R-studio..
thanks mate for helping me :lol: :lol:
dmarques
Postby dmarques » 21.04.08, 09:43
No problem :D
regedit
Postby regedit » 27.04.08, 11:37
prismakhas wrote:Yes, after run universal utility and perform express test..after that i have run hitachi utility and perform SA structure test.
I wat to unlock HTS541040G9AT00 by PC3000UDMA
please send to potograp unlock
send as soon as
thank
what should i do??
