Hi all
Yestertay i becom a WD2500JB. They nocked sixtimes, after twotimes and ather twotimes, but i could start util. after initiate Drive ID reading, Model, Serialnumber etc. loocks correct, so i could save all modules.
Today morning, the HD is nocking only. I dont have acces to firmware.
This is the log:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected 51/04 (ABR)
SA SPT.................................. : SA SPT determination error Techno CMD sending error Drive is not ready
Head number reading..................... : HDDs RAM reading error Techno CMD sending error Drive is not ready
ROM version............................. : 20.A7M
ROM generation.......................... : 20.A7M
Link table version...................... : 00.92.
Head map................................ : 0,1,2,3,4,5
Service area:
SA dir reading.......................... : Drive is not ready
what can i doo, to recover the data?
for help, i'm very greatful
Bruno
WD2500JB-00REA0
WD2500JB-00REA0 is Starling Family and unfortunately this is the problem with heads. This HDD has maximum capacity 250 Gb on six heads.
How to check heads you can read in manual of PC-3000: part WD, page 27, chapter 7.3.2 "Malfunction of drive heads and preamplifier-commutator".
But for data recovery from this HDD need read data from all heads, that is why it necessary to replace HSA from good donor HDD the same model: WD2500JB-xxRExx, where x - is unimportant symbol.
Replacement 6 heads is quite difficult procedure.
Best regards, Vadim Morozov
ACE Laboratory technical director
Hi Vadim
Shure is very difficult to change Heads, but we have anytime succesfull done wit WD 500GB (8 HEADs)
Tank you for your fast and competent answer!
I have another WD2500JB-00REA0, but this came from Malysia and is black. The patient Drive is from Thayland, do you now, is there the same MHA?
best regards
bruno
best regards
bruno
Zone allocation System
Hi all
I have a mistery problem with another WDJB2500-00REA0
Become Ready, No ID and could not read any user-sector. head test for all 6 heads on Cyl -50 are ok .
All modules are ok.
what i tont see??
thanks vor any help-
Bruno
Techno mode key:
Tech on................................. : Ok
SA SPT.................................. : 720
ROM version............................. : 20.A8M
ROM generation.......................... : 20.A8M
Service area:
SA dir reading.......................... : Ok (Copy 0)
All modules are ok.
what i tont see??
Bruno
Techno mode key:
Service area:
Nova wrote:I thought to exchange head on WD drives need to match DCM? last 4-5 digits of DCM?
I used to think so but our experience tells us that DCM on the label HDD not always correct describe HDA. That is why we check the following:
1. The same model/families;
2. The same head map;
3. The same factory is desirable.
Re: Zone allocation System
Bruno wrote:I have a mistery problem with another WDJB2500-00REA0
I agree with datalabace. If version of PCB and SA are different then will be the same situation. Second reason, may be from problem with ATA overlay module. This module may be damage by logic although check sum, header and other things are OK.
For data recovery use HOT-SWAP method but don't forget to prepare donor drive translator.
Hi datalabace, and all Helpers
You are on the right way. The Client sent now the original PCB to me.
This PCB is completely death. No Status-LED in PC3000UDMA are lighting.
Normal or Same Mode same nothing.
So, im solve the problem by unsolder the ROM-Chip from defect PCB and solder it to the good one.
All the data could be recovered.
Thanks all
Bruno
Thanks all
Bruno
