WD20EARS 60MVWB0 SA OK. head test OK But can't Read LBA .???
SA test OK.
HEAD test OK.
but :
Translator regeneration
Regeneration method..................... : Use P-List only
P-List Copy 0........................... : Ok
P-List Copy 1........................... : Ok
Error Code : 3C15....................... : FMT PLIST PSN OUT OF RANGE
ROM version............................. : 22.00E
ROM generation.......................... : 22.01E
Link table version...................... : 0B.36.
Consolidated ROM version................ : 00220000
ROM Modules:
Modules directory address............... : 377 654
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00220000
Service area:
Permanent overlay....................... : Loaded
Heads test
Cylinder to test........................ : -100
Heads to test........................... : 0,1,2,5,6,7
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 5.................................. : Ok
Head 6.................................. : Ok
Head 7.................................. : Ok
any solution . thanks for alll
- cuumaytinh
- cuumaytinh
Re: WD20EARS 60MVWB0 SA OK. head test OK But can't Read LBA
My P-list adn translation
- GuideRecovery
probably weak heads
did you try to image with selective heads
Wasim Zafar
https://mindmergepk.com
Wasim Zafar
- cuumaytinh
GuideRecovery wrote:probably weak heads
Yes. i did !. But not works
- GuideRecovery
try changing the head map to 1,2,3,5,6,7 > soft reset and than change it back to original 0,1,2,5,6,7
see if it works
see if it works
Wasim Zafar
Wasim Zafar
Try to set all heads to '0' then after soft reset try to read sector with H0. If no success, repeat with '1'. Do this because it is impossible to see which head is damaged, and heads 0 + 1 are SA heads.
- cuumaytinh
i was change good head from donor HDA but . no thing change !! .
can by P-list Error ??
If translator is good then plist should not be so important. did you check all SA modules for any errors before you changed heads? does it ID well?
- cuumaytinh
AJ2008 wrote:If translator is good then plist should not be so important. did you check all SA modules for any errors before you changed heads? does it ID well?
But Transkator error .
now i want to translator regenator . But it show error.
i try . Write Module 33 (P-list) to Good donor driver and transtator regenator . But it same error .
I think problem at plist.
"Error Code : 3C15....................... : FMT PLIST PSN OUT OF RANGE"
or some address of sector in plist error ????????????????
