WD DCO configuration identify error Device error detected
tarasheh
Postby tarasheh » 21.06.26, 15:35
Hello, I have WD5000LUCT and have DCO configuration identify error and i check module dirctory and all of them are okay.
how i can fix this error?
italyassistance
Re: WD DCO configuration identify error Device error detected
Postby italyassistance » 22.06.26, 18:20
paste your log, u save all modules and what is the problem? u can explain what kind of problem have your case?
tarasheh
Postby tarasheh » 27.06.26, 10:00
this is a stock hdd and after copy some files copy stop and smart show health 8% but i test this before in pc-3000 and i put it in writing and it finish without problem
Password set............................ : No
ATTENTION! Device has 8 logical sectors per physical sector.
DCO..................................... : DCO configuration identify error Device error detected "ABR"
Error scenario.......................... : Success
Set Max LBA............................. : Not supported
Capacity................................ : With no restrictions
S.M.A.R.T. drive status................. : GOOD
ID | Attribute | State | Value
5 | Reallocated Sector Count | Raw | 978
196 | Reallocation Events Count | Raw | 51
197 | Current Pending Sector Count | Ok | 0
198 | Uncorrectable Sector Count | Ok | 0
S.M.A.R.T............................... : Contains drive malfunction flags
Look ahead.............................. : Granted
Write cache............................. : Granted
Error recovery control.................. : Not supported
italyassistance
Postby italyassistance » 27.06.26, 10:35
I don't understand what you're asking, and what do you need to do, do you need to recover the data?
tarasheh
Postby tarasheh » 28.06.26, 07:33
oh yeah sorry i forgot to ask. I want to repair the drive back to normal stage i don't think it have bad sector or head problem if it had it must show in pc3k writing process
italyassistance
Postby italyassistance » 28.06.26, 15:36
tarasheh wrote:Source of the post oh yeah sorry i forgot to ask. I want to repair the drive back to normal stage i don't think it have bad sector or head problem if it had it must show in pc3k writing process
go in the pc3000 general utily and formatted disk with 00, if the process finish, attach disk in sata port and initialized disk and check with cristal disk or other software, if u can recover data, use DE for recostruction partition and save the data.
Users browsing this forum: Bing [Bot] and 8 guests
