kingmax 240gb SM2258XT HYN04
NSRGroup
Postby NSRGroup » 02.06.26, 09:49
Hi guys ,
i have a ssl 240 kingmax with sm2258xt with problem
Command execution error; Write sector error (LBA: 21 930); HDD DMA Redynes timeout (10000)
i have kast uodate 7.8.23 pc3000 and 3.8.10 SSD utility
Selected family......................... : ADATA SU650 (SM2258XT)
Controller.............................. : SM2258XT
SSD status:
Firmware mode........................... : ROM
Chips id................................ : AD5C282A0190
Vendor.................................. : Hynix
Type.................................... : 3dv4-72L TLC 8k
Loader uploading
MPISP code name......................... : U0330A0 HYNV4_00; T0710A(N)
U0330A0 HYNV4_00; T0710A(N)............. : Ok
Seed table reading
Completed
Microcode reading (0)................... : Ok
Firmware version (Internal)............. : U0330A0 HYNV4_00
SSD parameters reading.................. : Ok
Reset SSD controller.................... : Ok
Config Package.......................... : Ok
U0330A0 HYNV4_00; P0812(D).............. : Ok
Calling executable code................. : Command execution error; Write sector error (LBA: 21 930); HDD DMA Redynes timeout (10000)
SSD status:
SSD is in ready state................... : No
Firmware mode........................... : Unknown
SSD is locked........................... : Unknown
SSD is in Safe Mode..................... : Unknown
Operation aborted
Utility initialization was terminate!
Drive power supply...................... : OFF
is there any solution for that ?
italyassistance
Re: kingmax 240gb SM2258XT HYN04
Postby italyassistance » 20.06.26, 15:16
Postby Roman_TS » 21.06.26, 19:33
Don't forget the CHIP ID reading. All IDs should be on place. If something missed - there is a problem with physical correction.
Here is the instruction how to chose loader:
https://blog.acelab.eu.com/pc-3000-ssd- ... t-xt2.html
Return to “Other SSD”
