We have a NAND:
Foresee ncembs99-32g
02n1503117690
Which is an eMMC BGA chip. The controller is from an Intel Atom based processor which is built-in.
Is there any support with PC-3000 Flash for this NAND? (I have pictures attached).
Thank you
NAND Support - ncembs99-32g Topic is solved
- italyassistance
Re: NAND Support - ncembs99-32g
Pc-3000 flash dont have reader emmc bga
Re: NAND Support - ncembs99-32g Topic is solved
In theory you can read this eMMC with any third-party reader that allows to read eMMC as SD card. Should be easy - current chip doesn't have any encryption inside, and you don't need to read it via NAND interface. It's just memory with SD interface, will be detected in Windows as SD card.
italyassistance wrote:Source of the post Pc-3000 flash dont have reader emmc bga
Thank you for your response and input
Roman_TS wrote:Source of the post In theory you can read this eMMC with any third-party reader that allows to read eMMC as SD card. Should be easy - current chip doesn't have any encryption inside, and you don't need to read it via NAND interface. It's just memory with SD interface, will be detected in Windows as SD card.
Thank you. I will try this
I did get a reader. It does read as 32GB but shows as a RAW format. I tried R-Studio and UFS explorer and it will only run scans showing sectors as "Unrecognized"
I tried using PC-3000 with Disk analysis and it showed green sectors during the scan but still nothing. Same goes with RAW recovery. I assume the NAND has failed. Is there any other suggestion to try?
Thank you
