Is there any trick to find the correct loader or the ECC Error is not something that we can bypass?
I can't find any match with the type neither the info on the SSD back works as the firmware S1127B0.
These links don't help much in this case:
https://forum.acelab.eu.com/viewtopic.php?t=10909
https://blog.acelab.eu.com/pc-3000-ssd- ... t-xt2.html
Here is the log
Selected family......................... : KingDian S200
Controller.............................. : SM2258XT
SSD status:
Firmware mode........................... : ROM
Chips id................................ : 0xEC519A3F8CCB
Vendor.................................. : Samsung
Type.................................... : 3dv4-64L TLC 16k
Loader uploading
MPISP code name......................... : S1127B0 HYNV4_00; S1129A(N)
S1127B0 HYNV4_00; S1129A(N)............. : Ok
Seed table reading
Page reading (channel: 0; chip: 0; block: 0x0001; page: 0x0004); ECC error
Page reading (channel: 1; chip: 0; block: 0x0001; page: 0x0004); ECC error
Page reading (channel: 0; chip: 1; block: 0x0001; page: 0x0004); ECC error
Page reading (channel: 1; chip: 1; block: 0x0001; page: 0x0004); Command execution error; Read sector error (LBA: 21 930); DMA Data in command error. HDD Redynes timeout (10000)
Completed
ECC ERROR | SM2258XT Topic is solved
Re: ECC ERROR | SM2258XT Topic is solved
Drive is based on Samsung chips. I doubt that it would be possible to find a good loader for this drive.
- gameboybin
For 3 years. and i am getting the same exact error
Model : SM2258AB-80-10000000
Serial : (03)5526888-20080228
Firmware : 20141211
Capacity : 1 GB (2 096 640)
Selected family......................... : Crucial BX500
SSD status:
Chips id................................ : EC1ED93F88CB
Loader uploading
MPISP code name......................... : S0212B0 SSV3_00; R1211A(N)
S0212B0 SSV3_00; R1211A(N).............. : Ok
Invalid sectors per regions value (0xFFFF0000)
Seed table reading
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0004); ECC error
Table not found
channel: 0; chip: 0; block: 0x0000; page: 0x0001............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0003)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0005)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0009)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000F)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0011)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0015)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0017)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0019............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0021)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0023)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0027)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0029)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002F)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0033)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0035)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0039)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0041............ : Invalid page type (Wear Tbl/ISP)
channel: 0; chip: 0; block: 0x0000; page: 0x0043............ : Invalid page type (Wear Tbl/ISP)
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0045)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0047)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0001............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0003)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0005)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0009)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000F)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0011)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0015)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0017)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0019............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x001B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x001D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0021)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0023)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0027)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0029)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x002D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x002F)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0033)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0035)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0039)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x003B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0041............ : Invalid page type (Wear Tbl/ISP)
channel: 0; chip: 1; block: 0x0000; page: 0x0043............ : Invalid page type (Wear Tbl/ISP)
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0045)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0047)................. : ECC error
channel: 0; chip: 2; block: 0x0000; page: 0x0001............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0003)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0005)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0009)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x000B)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x000F)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0011)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0015)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0017)................. : ECC error
channel: 0; chip: 2; block: 0x0000; page: 0x0019............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x001B)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x001D)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0021)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0023)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0027)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0029)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x002D)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x002F)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0033)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0035)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0039)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x003B)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 2; block: 0x0000; page: 0x0041............ : Invalid page type (Wear Tbl/ISP)
channel: 0; chip: 2; block: 0x0000; page: 0x0043............ : Invalid page type (Wear Tbl/ISP)
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0045)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0047)................. : ECC error
channel: 0; chip: 3; block: 0x0000; page: 0x0001............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0003)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0005)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0009)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x000B)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x000F)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0011)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0015)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0017)................. : ECC error
channel: 0; chip: 3; block: 0x0000; page: 0x0019............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x001B)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x001D)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0021)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0023)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0027)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0029)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x002D)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x002F)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0033)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0035)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0039)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x003B)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 3; block: 0x0000; page: 0x0041............ : Invalid page type (Wear Tbl/ISP)
channel: 0; chip: 3; block: 0x0000; page: 0x0043............ : Invalid page type (Wear Tbl/ISP)
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0045)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0047)................. : ECC error
Firmware not loaded
SSD status:
Firmware mode........................... : LDR
Operation aborted
Firmware : 20141211
SSD status:
Loader uploading
Seed table reading
Table not found
Firmware not loaded
SSD status:
Operation aborted
Better Samsung NAND compatibility will be added in the upcoming 7.7x update. I recommend you to check this drive on the new version of software. As I mentioned 1 year ago, Samsung NAND chips were NOT supported in SM2258/2259 Utility.
when will we see this update?
In the nearest days.
- Matheus.recovery
Roman_TS wrote:Source of the post In the nearest days.
Hi Roman, I saw that in patch 7.7 features for Samsung 3dv5 and Samsung 3dv6 chips were implemented. I have a case with Samsung 3dv4 chip. Do you think it will work?
Chips id................................ : EC119B3F8ECB
Thank you.
You can try
- gameboybin
Matheus.recovery wrote:Roman_TS wrote:Source of the post In the nearest days.
Thank you.
How is 7.7 update going?? Have you been able to work with the SSD?
- Matheus.recovery
gameboybin wrote:Source of the postMatheus.recovery wrote:Roman_TS wrote:Source of the post In the nearest days.
Thank you.
I haven't paid for the upgrade yet. This attempt will be expensive.
- gameboybin
[/quote]
i am getting 7.7 next week
- MHS-Solutions
gameboybin wrote:Source of the post I haven't paid for the upgrade yet. This attempt will be expensive.
i am getting 7.7 next week[/quote]
Did you give it a try?
I'm having the same problem right now and only want to pay if I know that it works.
- italyassistance
i have 7.7.21 but i dont have a ssd with samsung nand for try it.
- MHS-Solutions
italyassistance wrote:i have 7.7.21 but i dont have a ssd with samsung nand for try it.
Ok too bad, I would need any confirmation if it's supported yet.
- MHS-Solutions
It's not supported, I've bought the update.
