wd5000bmvv-11a1cs0 rom
hddr49
Postby hddr49 » 03.05.25, 13:29
on this case I have the ROM gone (power surge I guess)
it's mariner, so no ROM modules backup in SA
The donor ROM I have are too far for ROM recovery or data recovery
Can someone provide me ROM for this case ?
wd5000bmvv-11a1cs0
firmware probably 01.01A01
Date : 23 DEC 2009
DCM HHBTJBBB
S/N WXB0AC9S6346
hddr49
Re: wd5000bmvv-11a1cs0 rom
Postby hddr49 » 03.05.25, 23:43
Precisions, firmware is close to 00140025. If I could fing a ROM of drive manufactured few days around, it will do the trick.
Postby digitalsupport » 05.05.25, 07:37
You can try a WXBOxxxx ROM, there are some in the HddSurgery FW database.
hddr49
Postby hddr49 » 05.05.25, 15:14
Yes, I have tried several of WXB0 roms from HddSurgery, without luck. I also try several WXB1, WXA and WXC...
Postby digitalsupport » 09.05.25, 15:38
How is the drive behaving with another WXB0xxxx ROM ?
hddr49
Postby hddr49 » 12.05.25, 19:17
Remains busy with WXB0 (640 Go BTW).
With a WXB1, drive spin up, get ready but kernel only, no ID and no Capacity.
If I run in normal mode, it doesn't detect SA SPT
Users browsing this forum: Bing [Bot] and 1 guest
