Hello everyone, I am working on a case involving an HGST HTS541010B7E610 drive, which is detected as part of the WD Palmer drive family. AT first sectors are readable; however, the drive slows down significantly when copying user files in the Data Extractor (DE). So I attempted to 'Solve Slow Responding Problems' procedure, locked UA writing, and applied T2 recovery. Shortly after, the sector editor stopped accessing the drive entirely, and even if i tried to get the sectors by utility mode and get access to the sectors I am unable to create tasks in the DE. Could someone please advise on how to proceed with this situation?
Here are the log Info:
SA SPT.................................. : 0
ROM Modules:
ROM version............................. : 02.1AP
Module 4F F/W version................... : 0002000J
Overlay F/W version..................... : 02.1BP
Servo F/W version....................... : 01.3C
Power up load dir data.................. : Yes
Power up load permovl................... : Yes
Power up load CFG data.................. : Yes
NN | Step | Time | Flags | Info | Description
62 | 20A | 4.83 s | 4000401214EFDFF | 5104370F | OVL_POWERUP_LOAD_RBBLIST(FM ERR HEADER II SIGNATURE INVALID)
66 | 227 | 4.83 s | 4000401216FFDFF | 51043746 | Load GPD-List (13A)(FM ERR NOT FOUND IN DIR)
85 | 223 | 5.60 s | 42884216DEFFDFF | 51043D9C | End Process 190(GPD-List (13A) not found)
DCM in module 47........................ : Z7
DCM in module 0A........................ : |R|3Z7AH39
To be able to create utilty based DE task, start "Prepare to get UA PBA access"
Family:................................. : Palmer 2.5"
System controller (SoC)................. : 88i1053A0 0x(5460)
Cyl Count............................... : 512
ROM Data size........................... : 1024 Kb
Modules directory address............... : 726 802
SA SPT.................................. : 1944
SA defects assigned..................... : 2
ROM Modules:
Service area:
Dir items loaded........................ : 544
Self encryption drive................... : No
UA writing.............................. : Blocked
DCM in module 02........................ : S|BRL|P3MZH7CARHV3KUUF
Drive identification reading ........... : Ok
HGST HTS541010B7E610 doesnt access sector edit and DE problem
Re: HGST HTS541010B7E610 doesnt access sector edit and DE problem
Slow respond solution should not run on this model. Also, I do not believe there was need to run T2 recovery
Second image shows overlays are not loaded. upload loader then upload DIR from SA then check modules directory to look for any modules with errors and proceed from there
hello, everyone, Please is there anyone have a donor loader for this case please, i have to work this case from scratch, but the case need the loader to go back and undo T2 Recovery and to cancel slow responding mode. please any suggestion will help
