Cannot unlock Bitlocker drive with Recovery Key
Postby gameboybin » 02.04.25, 03:33
I have a strange case. I have an SSD drive that comes with bitlocker an i do have the Recovery Key. However i am unable to decrypt the Drive cause PC3K keeps saying it is invalid Password
however I tried mapping the drive and opening it in R-Studio the key fits perfectly and unlock like normal
Don't know what happened to PC3K decryption?
Screenshot 2025-04-02 084635.png (390.08 KiB) Viewed 5190 times
DCDL
Re: Cannot unlock Bitlocker drive with Recovery Key
Postby DCDL » 02.04.25, 14:10
Following.
Had the same issue myself several times this week alone. PC3K saying invalid keys and password, but triple checked and is 100% the right keys and passwords. I did not have R-studio to try tho.
datasolution
Postby datasolution » 26.04.25, 18:40
I have same problem with palmer drive .It shows bitlocker but has clear key .Like ufs strait away open drive but drive has bad sectors so i want to image it but de ask for keys .strange .
DCDL
Postby DCDL » 01.05.25, 14:18
Anyone else having this issue?
Just had another job, exact same issue, DE reporting key is invalid when it 100% is correct. Doesn't seem to matter what model of drive as I've had it with mechanicals and SSDs.
DCDL
Postby DCDL » 02.05.25, 12:26
So turns out there is an issue and Acelabs are aware. I've been told there is a temporary fix, but without a support contract Acelabs wont help me. Hopefully this will help people going forward.
CamillePope
Postby CamillePope » 12.06.25, 07:12
Any update? Have you found any solution?
DCDL
Postby DCDL » 18.06.25, 11:24
CamillePope wrote:Source of the post Any update? Have you found any solution?
You need to contact TS and open a ticket. But if you have no active TS contract they will not provide the fix.
Return to “Data Extractor”
