I have issue with this drive trying to access to user data. I have unlocked ROM and swap USB pcb with compatible sata. The disk initilize it self in PC3k. I backed up most SA modules except 190. I get errors trying to read 190 module on both copies. When I try to access user data I get UNC error.
I am using latest version of PC3K software but has no experiance wiht these Palmer drives.
Please if somebody can help?
Palmer drive issue
- d_d_recovery
- User
Re: Palmer drive issue
Have you tried reading both copies of 190 ignoring reading errors then comparing both copies.
And you say you got 'most' of the SA, what else was missing?
Yes I tried but it aborts after while . Copy 0 is completely dead and Copy 1 header is ok but rest DEAD.
When I try sector edit I get UNC error.
- d_d_recovery
- User
No heads seams ok. No clicking sound or. Drive initilze normaly
- d_d_recovery
- User
emir_has wrote:Source of the post No heads seams ok. No clicking sound or. Drive initilze normaly
You didn't answer the questions about what other modules are not being read?
Here is list of backed up modules:
05/12/2024 22:03 <DIR> .
05/12/2024 22:03 <DIR> ..
04/12/2024 19:52 16,384 01.rpm
04/12/2024 19:54 3,584 02.rpm
04/12/2024 19:46 266,752 03.rpm
04/12/2024 19:54 3,597,824 04.rpm
04/12/2024 19:46 6,144 0C.rpm
04/12/2024 19:50 28,672 10.rpm
04/12/2024 19:52 35,840 1000.rpm
04/12/2024 19:47 20,992 1001.rpm
04/12/2024 19:50 25,088 1002.rpm
04/12/2024 19:54 29,696 1003.rpm
04/12/2024 19:50 34,304 1004.rpm
04/12/2024 19:47 23,040 1005.rpm
04/12/2024 19:56 20,480 1007.rpm
04/12/2024 19:46 25,088 1008.rpm
04/12/2024 19:52 23,552 1009.rpm
04/12/2024 19:52 33,280 100A.rpm
04/12/2024 19:52 19,456 100B.rpm
04/12/2024 19:56 22,016 100C.rpm
04/12/2024 19:54 19,456 100E.rpm
04/12/2024 19:50 20,992 1010.rpm
04/12/2024 19:52 27,648 1011.rpm
04/12/2024 19:56 22,016 1013.rpm
04/12/2024 19:52 512 102.rpm
04/12/2024 19:55 1,536 103.rpm
04/12/2024 19:55 512 104.rpm
04/12/2024 19:50 1,024 105.rpm
04/12/2024 19:53 1,024 106.rpm
04/12/2024 19:52 37,888 108.rpm
04/12/2024 19:50 524,800 109.rpm
04/12/2024 19:56 6,656 10A.rpm
04/12/2024 19:52 982,528 11.rpm
04/12/2024 19:47 8,192 1100.rpm
04/12/2024 19:53 65,536 1101.rpm
04/12/2024 19:50 65,536 1102.rpm
04/12/2024 19:49 65,536 1104.rpm
04/12/2024 19:55 8,192 1105.rpm
04/12/2024 19:49 65,536 1106.rpm
04/12/2024 19:55 65,536 1121.rpm
04/12/2024 19:50 59,392 115.rpm
04/12/2024 19:52 3,072 116.rpm
04/12/2024 19:50 23,552 118.rpm
04/12/2024 19:51 2,560 119.rpm
04/12/2024 19:54 1,534,976 120.rpm
04/12/2024 19:51 8,704 1205.rpm
04/12/2024 19:55 4,194,816 121.rpm
04/12/2024 19:56 512 123.rpm
04/12/2024 19:55 512 124.rpm
04/12/2024 19:52 8,192 1240.rpm
04/12/2024 19:54 512 125.rpm
04/12/2024 19:53 512 126.rpm
04/12/2024 19:46 512 127.rpm
04/12/2024 19:46 1,024 12B.rpm
04/12/2024 19:51 307,200 12D.rpm
04/12/2024 19:46 40,960 12E.rpm
04/12/2024 19:46 291,328 131.rpm
04/12/2024 19:46 32,768 132.rpm
04/12/2024 19:46 4,096 134.rpm
04/12/2024 19:46 56,320 13A.rpm
04/12/2024 19:51 122,880 13F1.rpm
04/12/2024 19:49 122,880 13F2.rpm
04/12/2024 19:49 3,584 13F5.rpm
04/12/2024 19:50 8,704 1400.rpm
04/12/2024 19:50 8,704 1410.rpm
04/12/2024 19:54 8,704 1430.rpm
04/12/2024 19:55 262,144 144.rpm
04/12/2024 19:51 131,584 146.rpm
04/12/2024 19:57 10,240 147.rpm
04/12/2024 19:46 88,064 14A.rpm
04/12/2024 19:46 512 150.rpm
04/12/2024 19:53 8,192 1500.rpm
04/12/2024 19:53 40,960 1501.rpm
04/12/2024 19:55 40,960 1502.rpm
04/12/2024 19:51 40,960 1503.rpm
04/12/2024 19:51 8,192 1504.rpm
04/12/2024 19:51 40,960 1505.rpm
04/12/2024 19:49 40,960 1506.rpm
04/12/2024 19:53 40,960 1507.rpm
04/12/2024 19:54 8,192 1508.rpm
04/12/2024 19:54 40,960 1509.rpm
04/12/2024 19:52 40,960 150A.rpm
04/12/2024 19:54 40,960 150B.rpm
04/12/2024 19:52 8,192 150C.rpm
04/12/2024 19:52 40,960 150D.rpm
04/12/2024 19:54 40,960 150E.rpm
04/12/2024 19:47 40,960 150F.rpm
04/12/2024 19:53 512 1530.rpm
04/12/2024 19:50 22,016 1531.rpm
04/12/2024 19:49 1,024 1532.rpm
04/12/2024 19:54 65,536 1533.rpm
04/12/2024 19:52 512 15A0.rpm
04/12/2024 19:50 1,024 15A2.rpm
04/12/2024 19:55 512 1640.rpm
04/12/2024 19:46 1,536 16F.rpm
04/12/2024 19:52 5,632 1800.rpm
04/12/2024 19:53 5,632 1801.rpm
04/12/2024 19:49 5,632 1802.rpm
04/12/2024 19:52 5,632 1810.rpm
04/12/2024 19:51 5,632 1811.rpm
04/12/2024 19:54 5,632 1812.rpm
04/12/2024 19:54 8,704 1820.rpm
04/12/2024 19:56 614,400 183.rpm
04/12/2024 19:56 512 188.rpm
04/12/2024 19:56 8,782,336 189.rpm
04/12/2024 19:55 1,024 18D.rpm
04/12/2024 19:49 90,112 18E.rpm
04/12/2024 19:52 512 191.rpm
04/12/2024 19:56 1,024 193.rpm
04/12/2024 19:50 1,024 194.rpm
04/12/2024 19:54 1,024 195.rpm
04/12/2024 19:53 1,024 196.rpm
04/12/2024 19:47 1,024 199.rpm
04/12/2024 19:47 1,024 19B.rpm
04/12/2024 19:51 6,656 19C.rpm
04/12/2024 19:54 7,680 19D.rpm
04/12/2024 19:52 6,144 19E.rpm
04/12/2024 19:52 2,048 19F.rpm
04/12/2024 19:47 512 1A4.rpm
04/12/2024 19:56 512 1A5.rpm
04/12/2024 19:50 10,240 1A6.rpm
04/12/2024 19:54 9,728 1A7.rpm
04/12/2024 19:56 6,144 1A8.rpm
04/12/2024 19:57 9,216 1A9.rpm
04/12/2024 19:56 93,184 1B.rpm
04/12/2024 19:56 4,608 1B2.rpm
04/12/2024 19:52 5,120 1B4.rpm
04/12/2024 19:50 2,048 1B8.rpm
04/12/2024 19:46 140,800 21.rpm
04/12/2024 19:52 140,800 23.rpm
04/12/2024 19:50 140,800 24.rpm
04/12/2024 19:49 342,528 2401.rpm
04/12/2024 19:51 329,728 2403.rpm
04/12/2024 19:53 235,008 2404.rpm
04/12/2024 19:49 314,880 2407.rpm
04/12/2024 19:51 245,760 2408.rpm
04/12/2024 19:53 296,960 2409.rpm
04/12/2024 19:51 209,920 240A.rpm
04/12/2024 19:55 218,624 240B.rpm
04/12/2024 19:55 234,496 240C.rpm
04/12/2024 19:55 259,072 240E.rpm
04/12/2024 19:55 163,840 2410.rpm
04/12/2024 19:49 180,224 2413.rpm
04/12/2024 19:53 265,216 2414.rpm
04/12/2024 19:53 182,272 2415.rpm
04/12/2024 19:49 221,184 241A.rpm
04/12/2024 19:53 224,256 241D.rpm
04/12/2024 19:49 226,304 241E.rpm
04/12/2024 19:51 231,936 241F.rpm
04/12/2024 19:55 436,736 2420.rpm
04/12/2024 19:49 234,496 2422.rpm
04/12/2024 19:51 133,120 2423.rpm
04/12/2024 19:55 226,304 2424.rpm
04/12/2024 19:53 278,016 2425.rpm
04/12/2024 19:51 175,104 2427.rpm
04/12/2024 19:49 184,320 2428.rpm
04/12/2024 19:51 235,520 2429.rpm
04/12/2024 19:53 327,680 242A.rpm
04/12/2024 19:49 215,040 242B.rpm
04/12/2024 19:55 250,368 242C.rpm
04/12/2024 19:51 263,680 242D.rpm
04/12/2024 19:55 238,080 242E.rpm
04/12/2024 19:51 197,120 242F.rpm
04/12/2024 19:55 162,304 2430.rpm
04/12/2024 19:51 260,608 2432.rpm
04/12/2024 19:49 234,496 2433.rpm
04/12/2024 19:53 171,520 2435.rpm
04/12/2024 19:53 153,600 2436.rpm
04/12/2024 19:53 275,968 243A.rpm
04/12/2024 19:55 232,960 243B.rpm
04/12/2024 19:49 246,784 243D.rpm
04/12/2024 19:55 260,096 243E.rpm
04/12/2024 19:51 198,656 243F.rpm
04/12/2024 19:51 355,328 2440.rpm
04/12/2024 19:49 180,736 2441.rpm
04/12/2024 19:55 293,376 2443.rpm
04/12/2024 19:53 314,368 2444.rpm
04/12/2024 19:49 306,688 2446.rpm
04/12/2024 19:51 260,096 244A.rpm
04/12/2024 19:49 173,568 244C.rpm
04/12/2024 19:51 253,440 244D.rpm
04/12/2024 19:53 221,696 244E.rpm
04/12/2024 19:55 161,792 244F.rpm
04/12/2024 19:49 202,240 2450.rpm
04/12/2024 19:53 240,640 2451.rpm
04/12/2024 19:55 217,088 2454.rpm
04/12/2024 19:55 131,584 25.rpm
04/12/2024 19:49 65,536 2500.rpm
04/12/2024 19:53 373,248 2503.rpm
04/12/2024 19:50 19,456 2504.rpm
04/12/2024 19:55 118,784 2507.rpm
04/12/2024 19:54 78,336 2509.rpm
04/12/2024 19:52 50,176 250A.rpm
04/12/2024 19:52 202,752 250B.rpm
04/12/2024 19:52 29,184 2513.rpm
04/12/2024 19:55 378,880 2514.rpm
04/12/2024 19:53 323,584 251E.rpm
04/12/2024 19:56 1,369,088 251F.rpm
04/12/2024 19:53 614,400 2520.rpm
04/12/2024 19:49 96,768 2522.rpm
04/12/2024 19:51 4,608 2527.rpm
04/12/2024 19:54 258,048 2529.rpm
04/12/2024 19:53 2,488,832 252A.rpm
04/12/2024 19:51 435,712 252D.rpm
04/12/2024 19:49 3,058,688 2533.rpm
04/12/2024 19:50 31,232 253A.rpm
04/12/2024 19:50 25,600 253B.rpm
04/12/2024 19:52 516,096 253D.rpm
04/12/2024 19:47 50,176 253E.rpm
04/12/2024 19:52 40,960 2541.rpm
04/12/2024 19:53 125,952 254D.rpm
04/12/2024 19:55 42,496 254E.rpm
04/12/2024 19:51 132,608 2551.rpm
04/12/2024 19:49 5,120 2552.rpm
04/12/2024 19:49 5,120 2553.rpm
04/12/2024 19:50 148,992 2554.rpm
04/12/2024 19:50 66,048 26.rpm
04/12/2024 19:55 51,712 2630.rpm
04/12/2024 19:49 51,712 2631.rpm
04/12/2024 19:51 6,144 2640.rpm
04/12/2024 19:54 6,144 2641.rpm
04/12/2024 19:50 348,672 2670.rpm
04/12/2024 19:56 349,184 2671.rpm
04/12/2024 19:51 48,128 2690.rpm
04/12/2024 19:50 41,984 2691.rpm
04/12/2024 19:53 984,064 26D0.rpm
04/12/2024 19:52 959,488 26D1.rpm
04/12/2024 19:55 99,328 26E0.rpm
04/12/2024 19:53 99,328 26E1.rpm
04/12/2024 19:50 289,792 2700.rpm
04/12/2024 19:54 289,792 2701.rpm
04/12/2024 19:55 131,072 2770.rpm
04/12/2024 19:53 130,560 2771.rpm
04/12/2024 19:53 8,192 28.rpm
04/12/2024 19:52 1,536 2810.rpm
04/12/2024 19:55 1,536 2811.rpm
04/12/2024 19:49 25,600 2820.rpm
04/12/2024 19:47 25,600 2821.rpm
04/12/2024 19:46 5,632 29.rpm
04/12/2024 19:54 5,632 2A.rpm
04/12/2024 19:51 1,491,968 2D.rpm
04/12/2024 19:55 20,480 2D3B.rpm
04/12/2024 19:52 1,024,000 2D54.rpm
04/12/2024 19:52 1,491,968 2E.rpm
04/12/2024 19:56 1,024 2E00.rpm
04/12/2024 19:50 512 2E23.rpm
04/12/2024 19:56 1,024 2F.rpm
04/12/2024 19:55 2,007,552 2F01.rpm
04/12/2024 19:54 42,496 2F46.rpm
04/12/2024 19:53 915,968 2FF0.rpm
04/12/2024 19:49 550,400 31.rpm
04/12/2024 19:46 30,720 32.rpm
04/12/2024 19:55 123,904 32D.rpm
04/12/2024 19:52 123,904 32E.rpm
04/12/2024 19:55 550,400 33.rpm
04/12/2024 19:53 151,552 3300.rpm
04/12/2024 19:55 166,912 3301.rpm
04/12/2024 19:51 179,712 3302.rpm
04/12/2024 19:53 143,872 3303.rpm
04/12/2024 19:53 161,280 3304.rpm
04/12/2024 19:48 169,984 3305.rpm
04/12/2024 19:49 173,056 3307.rpm
04/12/2024 19:51 144,896 3309.rpm
04/12/2024 19:53 142,848 3310.rpm
04/12/2024 19:55 137,216 3311.rpm
04/12/2024 19:49 139,264 3312.rpm
04/12/2024 19:47 186,368 3390.rpm
04/12/2024 19:46 24,576 34.rpm
04/12/2024 19:48 205,824 3400.rpm
04/12/2024 19:49 201,216 3402.rpm
04/12/2024 19:53 200,704 3405.rpm
04/12/2024 19:51 198,144 3406.rpm
04/12/2024 19:51 198,656 3407.rpm
04/12/2024 19:55 198,656 3408.rpm
04/12/2024 19:55 138,752 3411.rpm
04/12/2024 19:51 204,288 3413.rpm
04/12/2024 19:53 140,800 3414.rpm
04/12/2024 19:51 149,504 3416.rpm
04/12/2024 19:48 201,728 3417.rpm
04/12/2024 19:55 206,848 3421.rpm
04/12/2024 19:51 163,328 3422.rpm
04/12/2024 19:48 160,768 3423.rpm
04/12/2024 19:55 166,912 3424.rpm
04/12/2024 19:49 163,840 3425.rpm
04/12/2024 19:53 162,816 3426.rpm
04/12/2024 19:55 139,776 3429.rpm
04/12/2024 19:53 205,824 3430.rpm
04/12/2024 19:51 207,872 3431.rpm
04/12/2024 19:53 242,688 34D1.rpm
04/12/2024 19:55 248,320 34D2.rpm
04/12/2024 19:49 248,832 34D3.rpm
04/12/2024 19:51 256,512 34D4.rpm
04/12/2024 19:51 221,184 34D5.rpm
04/12/2024 19:53 260,096 34D6.rpm
04/12/2024 19:49 260,096 34D7.rpm
04/12/2024 19:55 147,456 34D8.rpm
04/12/2024 19:53 255,488 34D9.rpm
04/12/2024 19:55 252,928 34DA.rpm
04/12/2024 19:51 16,384 34E7.rpm
04/12/2024 19:56 5,120 35.rpm
04/12/2024 19:55 198,144 3500.rpm
04/12/2024 19:55 204,800 3501.rpm
04/12/2024 19:48 198,144 3502.rpm
04/12/2024 19:48 197,632 3503.rpm
04/12/2024 19:53 204,800 3504.rpm
04/12/2024 19:53 138,752 3511.rpm
04/12/2024 19:51 243,712 3513.rpm
04/12/2024 19:49 251,392 3514.rpm
04/12/2024 19:51 199,680 3516.rpm
04/12/2024 19:49 193,024 3517.rpm
04/12/2024 19:51 172,544 3518.rpm
04/12/2024 19:53 148,992 3551.rpm
04/12/2024 19:46 29,696 36.rpm
04/12/2024 19:49 306,176 360.rpm
04/12/2024 19:53 8,192 3604.rpm
04/12/2024 19:48 139,776 3605.rpm
04/12/2024 19:46 1,024 361.rpm
04/12/2024 19:51 1,024 37.rpm
04/12/2024 19:49 198,656 3700.rpm
04/12/2024 19:55 171,008 3703.rpm
04/12/2024 19:50 169,984 3706.rpm
04/12/2024 19:51 131,584 38.rpm
04/12/2024 19:55 20,480 3801.rpm
04/12/2024 19:53 1,024 3802.rpm
04/12/2024 19:55 8,704 39.rpm
04/12/2024 19:55 6,144 3A.rpm
04/12/2024 19:54 8,192 3B.rpm
04/12/2024 19:56 8,192 3C.rpm
04/12/2024 19:55 16,384 3C00.rpm
04/12/2024 19:54 58,368 3C10.rpm
04/12/2024 19:56 58,368 3C11.rpm
04/12/2024 19:50 58,368 3C20.rpm
04/12/2024 19:53 58,368 3C21.rpm
04/12/2024 19:53 8,192 3D.rpm
04/12/2024 19:54 8,192 3E.rpm
04/12/2024 19:54 1,024 3E00.rpm
04/12/2024 19:52 145,408 3E01.rpm
04/12/2024 19:47 8,192 3F.rpm
04/12/2024 19:51 512 3F00.rpm
04/12/2024 19:53 4,096 3F01.rpm
04/12/2024 19:54 25,600 3F03.rpm
04/12/2024 19:47 5,632 3F04.rpm
04/12/2024 19:51 15,360 3F05.rpm
04/12/2024 19:54 25,600 3F06.rpm
04/12/2024 19:46 291,328 40.rpm
04/12/2024 19:46 512 4002.rpm
04/12/2024 19:49 291,328 41.rpm
04/12/2024 19:50 126,976 411.rpm
04/12/2024 19:49 291,328 42.rpm
04/12/2024 19:47 291,328 43.rpm
04/12/2024 19:46 1,536 49.rpm
04/12/2024 19:46 13,312 4A.rpm
04/12/2024 19:46 512 4D.rpm
04/12/2024 19:50 55,808 4E.rpm
04/12/2024 19:46 1,536 50.rpm
04/12/2024 19:46 1,536 51.rpm
04/12/2024 19:54 1,536 52.rpm
04/12/2024 19:54 512 52E.rpm
04/12/2024 19:57 1,536 53.rpm
04/12/2024 19:56 1,536 600.rpm
04/12/2024 19:55 512 601.rpm
04/12/2024 19:50 512 62.rpm
04/12/2024 19:53 140,800 68.rpm
04/12/2024 19:53 140,800 69.rpm
04/12/2024 19:50 140,800 6A.rpm
04/12/2024 19:56 1,536 6B.rpm
04/12/2024 19:54 1,024 6D.rpm
04/12/2024 19:54 1,024 6E.rpm
04/12/2024 19:46 188,928 6F.rpm
04/12/2024 19:47 1,024 8000.rpm
04/12/2024 19:50 1,024 8001.rpm
04/12/2024 19:52 1,024 8002.rpm
04/12/2024 19:50 2,048 8003.rpm
04/12/2024 19:47 1,536 8004.rpm
04/12/2024 19:54 1,024 8005.rpm
04/12/2024 19:54 1,024 8006.rpm
04/12/2024 19:55 1,024 8007.rpm
04/12/2024 19:54 1,024 8008.rpm
04/12/2024 19:49 1,024 8009.rpm
04/12/2024 19:55 1,024 800A.rpm
04/12/2024 19:52 1,024 800B.rpm
04/12/2024 19:50 1,024 800C.rpm
04/12/2024 19:50 2,560 800D.rpm
04/12/2024 19:49 2,560 800E.rpm
04/12/2024 19:54 2,560 800F.rpm
04/12/2024 19:52 2,560 8010.rpm
04/12/2024 19:52 2,560 8011.rpm
04/12/2024 19:50 2,560 8012.rpm
04/12/2024 19:52 2,560 8013.rpm
04/12/2024 19:50 2,560 8014.rpm
04/12/2024 19:50 1,024 8015.rpm
04/12/2024 19:52 2,560 8016.rpm
04/12/2024 19:56 2,560 8017.rpm
04/12/2024 19:55 1,024 8018.rpm
04/12/2024 19:49 2,560 8019.rpm
04/12/2024 19:52 2,560 801A.rpm
04/12/2024 19:55 16,896 801B.rpm
04/12/2024 19:54 1,024 801C.rpm
04/12/2024 19:50 16,896 801D.rpm
04/12/2024 19:54 62,976 801E.rpm
04/12/2024 19:50 1,024 801F.rpm
04/12/2024 19:52 2,048 8020.rpm
04/12/2024 19:53 1,536 8021.rpm
04/12/2024 19:50 2,560 8022.rpm
04/12/2024 19:54 1,536 8023.rpm
04/12/2024 19:52 1,024 8024.rpm
04/12/2024 19:52 1,024 8025.rpm
04/12/2024 19:46 9,216 8026.rpm
04/12/2024 19:49 1,024 8027.rpm
04/12/2024 19:50 2,048 8028.rpm
04/12/2024 19:51 1,024 8029.rpm
04/12/2024 19:52 1,024 802A.rpm
04/12/2024 19:54 2,560 802B.rpm
04/12/2024 19:47 1,536 802C.rpm
04/12/2024 19:50 16,896 802D.rpm
04/12/2024 19:50 4,096 802E.rpm
04/12/2024 19:47 4,096 802F.rpm
04/12/2024 19:54 1,024 8030.rpm
04/12/2024 19:47 2,048 8031.rpm
04/12/2024 19:55 4,096 8032.rpm
04/12/2024 19:52 6,656 8033.rpm
04/12/2024 19:53 16,896 8034.rpm
04/12/2024 19:49 8,192 8035.rpm
04/12/2024 19:55 8,192 8036.rpm
04/12/2024 19:55 1,024 8037.rpm
04/12/2024 19:50 1,024 8038.rpm
04/12/2024 19:53 1,024 8039.rpm
04/12/2024 19:54 1,024 803A.rpm
04/12/2024 19:55 1,024 803B.rpm
04/12/2024 19:52 1,024 803C.rpm
04/12/2024 19:51 1,024 803D.rpm
04/12/2024 19:52 1,024 803E.rpm
04/12/2024 19:56 1,024 803F.rpm
04/12/2024 19:50 1,024 8040.rpm
04/12/2024 19:52 1,024 8041.rpm
04/12/2024 19:51 1,024 8042.rpm
04/12/2024 19:53 1,024 8043.rpm
04/12/2024 19:50 1,024 8044.rpm
04/12/2024 19:54 1,024 8045.rpm
04/12/2024 19:54 1,024 8046.rpm
04/12/2024 19:47 16,896 8047.rpm
04/12/2024 19:56 6,656 8048.rpm
04/12/2024 19:55 12,800 8049.rpm
04/12/2024 19:53 2,560 804A.rpm
04/12/2024 19:51 6,656 804B.rpm
04/12/2024 19:47 2,560 804C.rpm
04/12/2024 19:49 6,656 804D.rpm
04/12/2024 19:53 51,200 804E.rpm
04/12/2024 19:52 1,536 804F.rpm
04/12/2024 19:54 2,560 8050.rpm
04/12/2024 19:54 6,656 8051.rpm
04/12/2024 19:47 8,192 8052.rpm
04/12/2024 19:55 2,560 8053.rpm
04/12/2024 19:50 6,656 8054.rpm
04/12/2024 19:55 2,560 8055.rpm
04/12/2024 19:51 6,656 8056.rpm
04/12/2024 19:51 2,560 8057.rpm
04/12/2024 19:50 6,656 8058.rpm
04/12/2024 19:50 2,560 8059.rpm
04/12/2024 19:52 6,656 805A.rpm
04/12/2024 19:56 8,192 805B.rpm
04/12/2024 19:56 1,024 805C.rpm
04/12/2024 19:53 2,560 805D.rpm
04/12/2024 19:51 6,656 805E.rpm
04/12/2024 19:55 8,192 805F.rpm
04/12/2024 19:47 1,024 8060.rpm
04/12/2024 19:50 1,024 8061.rpm
04/12/2024 19:49 6,656 8062.rpm
04/12/2024 19:52 6,656 8063.rpm
04/12/2024 19:47 2,560 8064.rpm
04/12/2024 19:50 16,896 8065.rpm
04/12/2024 19:52 1,024 8066.rpm
04/12/2024 19:51 2,560 8067.rpm
04/12/2024 19:53 6,656 8068.rpm
04/12/2024 19:46 12,800 8069.rpm
04/12/2024 19:55 1,536 806A.rpm
04/12/2024 19:52 10,752 806B.rpm
04/12/2024 19:47 2,048 806C.rpm
04/12/2024 19:50 5,632 806D.rpm
04/12/2024 19:56 16,896 806E.rpm
04/12/2024 19:51 5,120 806F.rpm
04/12/2024 19:55 2,560 8074.rpm
04/12/2024 19:56 1,024 80FC.rpm
04/12/2024 19:54 16,384 80FE.rpm
04/12/2024 19:55 25,600 80FF.rpm
04/12/2024 19:51 2,048 8108.rpm
04/12/2024 19:52 512 8FFC.rpm
04/12/2024 19:56 4,096 8FFD.rpm
04/12/2024 19:50 8,192 8FFE.rpm
04/12/2024 19:50 30,720 9A.rpm
04/12/2024 19:57 512 AC55.rpm
04/12/2024 19:54 26,624 B1.rpm
04/12/2024 19:56 30,720 B2.rpm
04/12/2024 19:53 1,048,064 B5.rpm
04/12/2024 19:53 198,144 B6.rpm
04/12/2024 19:56 3,072 B7.rpm
04/12/2024 19:55 1,536 B8.rpm
04/12/2024 19:53 204,800 B9.rpm
04/12/2024 19:48 206,848 BA.rpm
04/12/2024 19:55 199,168 BC.rpm
04/12/2024 19:53 216,576 BD.rpm
04/12/2024 19:55 3,584 BE.rpm
04/12/2024 19:48 4,096 BF.rpm
04/12/2024 19:55 425,984 C5.rpm
04/12/2024 19:50 5,632 CC.rpm
04/12/2024 19:50 512 D000.rpm
04/12/2024 19:52 512 D001.rpm
04/12/2024 19:56 512 D002.rpm
04/12/2024 19:51 512 D003.rpm
04/12/2024 19:56 512 D004.rpm
04/12/2024 19:47 512 D005.rpm
04/12/2024 19:46 512 D006.rpm
04/12/2024 19:53 90,112 D009.rpm
04/12/2024 19:50 1,024 D010.rpm
04/12/2024 19:49 218,624 D1.rpm
04/12/2024 19:53 137,216 D3.rpm
04/12/2024 19:55 145,408 D4.rpm
04/12/2024 19:55 215,040 D5.rpm
04/12/2024 19:51 197,120 D7.rpm
04/12/2024 19:51 139,776 D8.rpm
04/12/2024 19:51 203,776 DB.rpm
04/12/2024 19:51 180,736 DC.rpm
04/12/2024 19:55 196,096 DD.rpm
04/12/2024 19:51 207,360 DE.rpm
04/12/2024 19:53 219,136 DF.rpm
04/12/2024 19:54 1,280,000 E0.rpm
04/12/2024 19:55 1,280,000 E1.rpm
04/12/2024 19:49 53,760 E6.rpm
04/12/2024 19:52 16,384 E7.rpm
04/12/2024 19:55 466,944 E8.rpm
04/12/2024 19:56 466,944 E9.rpm
04/12/2024 19:52 1,024 EE.rpm
04/12/2024 19:55 460,800 EF.rpm
04/12/2024 19:55 194,048 F7.rpm
04/12/2024 19:50 131,072 FA.rpm
04/12/2024 19:47 2,048 FC.rpm
04/12/2024 19:55 32,768 FD.rpm
04/12/2024 19:53 1,024,000 FE.rpm
04/12/2024 19:49 1,024,000 FF.rpm
So all major modules are here except 190
- d_d_recovery
- User
Are those modules from Copy 1, 2 or composite?
From Copy 0 on pic but Copy 1 is also backed up.
Anyone please. How to solve this issue?
Read 190 with error ignore as suggested. It is important to have a copy of it.
You can read data using T2. Your T2 looks ok.
I can help remotely.
I am trying to read 190 module with ignore reading and composite whole night and still did not finished.
I will wait till finishes now and report back again if need remote assistance.
Thank you northwind I will get back info.
I have read T2 in combine reading and error ignoring options on. I have repaired T2 file with utility as post in blog and recorded back to disk.
Now disk cannot initialize and when I tried upload overlay modules I get errors.
Please if someone could help?
