Hi everyone.
I have a Verabtim Vi550 S3 512 GB SATA SSD which uses the Maxio MAS0902A-B2C controller.
Single NAND chip, with markings NG70TAA1442512G, recognized as AD89285300B0
The only 2 posts regarding this controller are from the start of the year. The presentation video for version PC-3000 7.5.x shows that other drives based on MAS0902A, which are not listed as supported, might be supported under the Default tab.
This specific NAND package is not in the list under the default option.
Would this drive be supported?
Thank you
Verbatim Vi550 S3 512GB with MAS0902A-B2C
- d_d_recovery
- User
Re: Verbatim Vi550 S3 512GB with MAS0902A-B2C
FWIU the new 'Maxio default' utility is not ready to use yet. Should be in the next update (hopefully).
It depends on the NAND chips that were in use on your drive. Please make a ticket, we will try to guide you.
Thank you Roman_TS, d_d_recovery for your replies.
Roman_TS we're waiting for the next PC3k update to renew our support. No point in doing it now for a drive with low chances of recovery.
Thank you again.
Thank you again.
