help to recover data frm sd card 256gb
italyassistance
Re: help to recover data frm sd card 256gb
Postby italyassistance » 21.09.24, 10:05
Roman,
have you ever seen anything like this?
Immagine 2024-09-21 101133.jpg (147.16 KiB) Viewed 6908 times
Immagine 2024-09-21 101230.jpg (183 KiB) Viewed 6908 times
Immagine 2024-09-21 101341.jpg (13.27 KiB) Viewed 6908 times
Immagine 2024-09-21 101201.jpg (264.16 KiB) Viewed 6908 times
Postby Roman_TS » 21.09.24, 21:10
Roman is available in the Ticket System :D
Anyway, it's a typical issue of the NAND buffers corruption. In other words - the NAND chip is reading the same page again and again.
You can try to "play" with the voltage and read this chip with different power settings. But usually, there arn't so many chances to recover it... It's a hardware issue.
