help to recover data from sd card 512gb
deyaa2012
Postby deyaa2012 » 05.07.24, 16:40
Help in recover Lexar 512 as seen not detected over any reader or over pc3000 flash sd card adapter
WhatsApp Image 2024-07-05 at 17.35.56_282df8ee.jpg (266.2 KiB) Viewed 4194 times
Re: help to recover data from sd card 512gb
Postby Roman_TS » 05.07.24, 20:24
Hello. You need to remove the plastic cover. Most likely it's based on two BGA-132 + SM2704
deyaa2012
Postby deyaa2012 » 05.07.24, 21:48
It’s like that like there is sealed or protective no chip appeared
deyaa2012
Postby deyaa2012 » 06.07.24, 17:34
In such case any solution to remove protective cover or in this case using spider board ?
deyaa2012
Postby deyaa2012 » 08.07.24, 08:03
Can you guide me in such case what we will do ?
Postby Roman_TS » 09.07.24, 10:02
You should grind the bottom side of the monolith and try to find the target layout.
