Rosewood_AF , LED:0x000000BB FAddr:0x00004300 error
Issam
Postby Issam » 20.04.24, 14:14
I have the disk:
ST2000LM007 SITE: WU FW: EB01 PN: 1R8174-57
It spins normally, After power on it the terminal shows the following error ONLY no any other text:
I cannot patch it, I read the Rom via reader and patched it, then copied again to the Original Rom, same result
Any one have an idea about what is happening
thank you
Masterclass
Re: Rosewood_AF , LED:0x000000BB FAddr:0x00004300 error
Postby Masterclass » 23.04.24, 07:37
Do you use recent utility version?
Issam
Postby Issam » 23.04.24, 07:38
yes, 7.3.17 version
Issam
Postby Issam » 29.04.24, 13:37
Hope Ace Ts have an idea bout this issue
Masterclass
Postby Masterclass » 02.05.24, 12:22
recent is 7.4. You need to patch rom image using a recent utility ver
Issam
Postby Issam » 02.05.24, 12:37
I will prepare to have new TS contract, but i need someone to patch it for me with the new version... if you can ,
Issam
Postby Issam » 03.05.24, 00:06
TS AT ACE patched for me the rom with 7.4 versuon ( thank you). But same error appears...
roham
Postby roham » 22.04.25, 07:40
Hello dear
I also see the LED BB error in the terminal. Of course, my hard drive is ST6000NM0115.
If you find a solution, I would appreciate it if you could share it with me.
Thank you
