Hello, does anybody know if this SD card use LDPC ? I don't have pinout for this so I wonder if it's worth to find the correct one.
Thank you
Sandisk Extreme 128GB LDPC?
Re: Sandisk Extreme 128GB LDPC?
Solved. It's LDPC.
- Chetan1207
Hi Datahelp,
What was the problem you were facing with this ?
Hi, this card uses LDPC algorithm + probably encryptioin, so there is no way at this moment to solve it.
- Chetan1207
Hi, Thanks for the reply
Ok, I get it but you mentioned that you have solved this case. So I was asking what problem were you facing??
Sorry, I mean the problem was "solved" (not the case), because it's imposible to recover this card.
