look for pinout, or datasheet for SKhynix h230dg8ud1acs
Typical Flash recovery cases
oldman
Postby oldman » 30.03.24, 03:14
It can be found in the iPhone 6s, but my one is from a USB stick, 16GB.
Thanks.
Philip
ps: 16gb SKhynix h230dg8ud1acs
oldman
Re: look for pinout, or datasheet for SKhynix h230dg8ud1acs
Or it will be better if there is a reader adapter for this chip.
Thanks.
Philip
Postby Roman_TS » 01.04.24, 12:12
Hello. It's a refurbished BGA-70.
We are not planning to release adapter for this type of memory chips because it's very rare type, that you can meet only in Flash cases with refurbished chips from dead iPhones.
Also, it usually has an additional problem with a normal reading because it's a EZ-NAND memory with hardware ECC inside.
oldman
Postby oldman » 01.04.24, 22:20
Thanks Roman, Great helpful.
Philip
