Too many bad sectors made it almost impossible to read in USB mode
So i Soldered SATA cable instead
- Unlock ROM and WROTE it back to original PCB through POGO PINS
- Drive Comes Fully Ready
- However after Decrypting the data table wont show up in DE
- Through Sector Edit. Sectors before decryption was readable. After decryption is not readable
- Got error messages when Building Heads map
Can anyone help me with this???
- I have tried Block Module 30 and Upload back to ROM
- Block and shift SA
Model : WDC WD40NDZW-11A8JS1
Serial : WD-WXQ2E60CUVW1
Firmware : 01.01A01
Capacity : 4 TB (7 813 971 632)
Code: Select all
Family:................................. : SpyGlass2 Ultra 2.5"
RAM:
System controller (SoC)................. : 88i1054A1 0x(5471)
Heads number............................ : 10
Cyl Count............................... : 384
ROM:
Modules directory address............... : 801 050
SA SPT.................................. : 2136
SA defects assigned..................... : 17
ROM Modules:
ROM version............................. : 00.0AA
Module 4F F/W version................... : 0000000A
Overlay F/W version..................... : 00.0BA
Servo F/W version....................... : 03.7B
Heads number in use..................... : 10
Heads map............................... : 0,1,2,3,4,5,6,7,8,9
Relocations............................. : 0 (2 459)
Read ROM DCM............................ : Ok
Power up load dir data.................. : Yes
Power up load permovl................... : Yes
Power up load CFG data.................. : Yes
Service area:
Dir items loaded........................ : 644
CFG tech mode lock...................... : No
Self encryption drive................... : Yes
SED Info read........................... : Ok
Master Password......................... : No
User Password........................... : No
SED tech mode lock...................... : No
UA writing.............................. : Granted
DCM in module 47........................ : ZE
DCM in module 0A........................ : |W|MZEDH2F
DCM in module 02........................ : S|BWL|PMMZHECDRHV2KBUNHERE IS THE CODE WHEN DECRYPTING
Code: Select all
SED key checking
Key 018D................................ : Module 18D not found
Key 018E................................ : Module 18E not found
Encryption.............................. : Self Encryption HDD v2
SED key checking
External encryption key checking
UA key reading:7 813 965 856............ : Ok
SA key reading:Copy 0................... : Ok
SA key reading:Copy 1................... : Ok
UA key reading:7 813 967 235............ : Ok
UA key reading:7 813 965 832............ : Ok
SA key reading:Copy 0................... : Has been already read
SA key reading:Copy 1................... : Has been already read
UA key reading:7 813 971 592............ : OkHERE IS CODE WHEN BUILDING HEADS MAP
Reading method.......................... : VSC command (T2 Data read)
T2 read................................. : Ok
Zone type............................... : Type 2
Zones................................... : 5 865
SMR zone read........................... : Ok
SMR zone indexing....................... : Ok
26 329 / 9.............................. : 193 030 -- 195 885 # 173 119
26 329 / 10............................. : 196 121 -- 196 983 # 173 119
2 296 / 4............................... : 197 227 -- 203 049 # 173 119
2 296 / 12.............................. : 203 050 -- 208 570 # 173 119
38 749 / 5.............................. : 208 571 -- 214 399 # 173 119
41 036 / 4.............................. : 206 153 -- 206 860 # 176 129
58 306 / 4.............................. : 206 861 -- 207 364 # 176 129
58 306 / 7.............................. : 207 365 -- 207 857 # 176 129
......................STILL MORE AFTER THIS................
MBA <0> to CHS convert error Device Error Detected: "VSC ERR VSC MODE DISABLED"
