WD5000BMVV-11GNWS0 Marn5_4K data not showing in DE
Hddex
Postby Hddex » 13.02.24, 21:54
I have a 500GB WD5000BMVV-11GNWS0 Marn5_4K. It was not reading via USB, so I converted it to SATA. Everything looks healthy in PC-3000: normal mode, kernel mode, and sector edit. In DE, I mapped the head and checked the head surface, everything appears OK. However, I cannot access the drive using Explorer; it will not expand or show the NTF partition. What am I missing? See the screenshot.
Re: WD5000BMVV-11GNWS0 Marn5_4K data not showing in DE
Postby digitalsupport » 13.02.24, 22:19
Show content of sector 0, did you check for encryption ?
Hddex
Postby Hddex » 13.02.24, 23:04
digitalsupport wrote:Source of the post Show content of sector 0, did you check for encryption ?
Thank you for your response. Here is the screen shot for sector 0 and yes I did follow the steps here :
https://blog.acelab.eu.com/pc-3000-hdd- ... ome%20time.
Hddex
Postby Hddex » 13.02.24, 23:49
I also created an image in DE and tried to decrypt and when I click on the sector it looks like is not decrypting.
Hddex
Postby Hddex » 14.02.24, 00:36
I just noticed in the log : There are no key dir modules
Hddex
Postby Hddex » 14.02.24, 02:02
Resolved :
The issue was resolved by creating an image in DE and then decrypt the image (it did take over 2 hours with a healthy drive). I was not able to do it from utilities.
Return to “Data Extractor”
