I have a case which I was working on PORT 1 of PC3000 Express.
Later that port got busy by another case
I changed the earlier case from PORT 1 to PORT 0 and got the error bellow
Port not found!
Is there any way that i can change the project to read data from other PORT???
Thank you!
How to change Ports That the drive was working on??
- gameboybin
- digitalsupport
- User
Re: How to change Ports That the drive was working on??
Connect patient drive to the desired port.
When you open the task you can change port to current in the dialog
