Help! Toshiba 2.5 MQ04ABF100 cannot Data Extract
Postby gameboybin » 21.03.23, 10:16
I have a Toshiba 2.5 Drive 1TB
The ID read normal
Got 9 Defects in G-list
All backups was run well
But i cannot get to Data Extract
In Data Extraction shows LBA errors
Can somebody help. Thanks!
Re: Help! Toshiba 2.5 MQ04ABF100 cannot Data Extract
Postby gameboybin » 06.04.23, 06:59
Can anyone help :(
cis_rec
Postby cis_rec » 09.01.24, 04:57
gameboybin wrote:Source of the post Can anyone help :(
did you manage to solve this issue ? i have the same here
gersh
Postby gersh » 08.07.24, 12:11
cis_rec wrote:Source of the post
Hi somebody solved this problem?
now i try read by PBA with utility, get some raw data.
italyassistance
Postby italyassistance » 18.12.24, 14:38
The strange thing about these drives is that when you convert them to sata, there is a huge difficulty in reconstructing the partition, folders and files, most of the time you are forced to do a raw recovery because the structure is always partial or non-existent, plus even changing the text set, it reads more or less slowly, from a minimum of 500kb to a maximum of no more than 5-10mb/s, does anyone have any suggestions regarding the reconstruction of the structure, folders and files?
northwind
Postby northwind » 20.12.24, 09:19
It's not strange, that's because these drives get upset when they're not WP'ed.
hdd00
Postby hdd00 » 21.12.24, 08:24
Ok . So can somebody, Acelab included, tell us how to WP them?
italyassistance
Postby italyassistance » 23.12.24, 12:01
Would changing the USB PCB with a known working one help?
Return to “Toshiba native”
