I am just uploading this cases for the future updates of PC3000
DSS Digital surveillance system SSD from Dahua
Using SM2259XT controller
Model : SM59XT2A-80-50000001
Serial : (03)5526888-20080228
Firmware : 20210308
Capacity : 1 GB (2 096 640)
Selected family......................... : Silicon Power Slim S55 (SM2259XT)
Controller.............................. : SM2259XT
SSD status:
Firmware mode........................... : ROM
Chips id................................ : 453E98037664
Vendor.................................. : Sandisk
Type.................................... : 112L BiCS5 TLC 16k
Loader uploading
MPISP code name......................... : U1124A0 FBiCS5_06 (XT2); U0915A(N)
U1124A0 FBiCS5_06 (XT2); U0915A(N)...... : Ok
Seed table reading
Completed
Microcode reading (0)................... : Ok
Firmware version (Internal)............. : U1224A0 FBiCS5_08
SSD parameters reading.................. : Ok
Loader not found by internal name.
Search for compatible loaders...
U0916A0 FBiCS5_06 (XT2); U0915A(N)...... : Ok
Reset SSD controller.................... : Ok
Config Package.......................... : Ok
U0916A0 FBiCS5_06 (XT2); Q0209(D)....... : Ok
Invalid FW mode 5 (0)
SSD status:
SSD is in ready state................... : No
Firmware mode........................... : Unknown
SSD is locked........................... : Unknown
SSD is in Safe Mode..................... : Unknown
Operation aborted
Utility initialization was terminate!
SM2259XT New Firmware, Loader needed in future SSD updates
- gameboybin
Re: SM2259XT New Firmware, Loader needed in future SSD updates
Sandisk BiCS5 support will appear in the upcoming update. But again, I want to remind you that PC-3000 Forum - is the place where ACELab customers are able to communicate with each other. If you need a help with case support, please contact ts.acelab.eu.com
- datasalvage
Same problem here! Invalid FW mode 5 (0) iv selected the firmware suggested by the utility but i get Invalid FW mode 5 (0) ! sometime i can rebuild the translator but serial number and capacity doesnt change! im stuck
Passport ID in Utility means nothing. It always shows you the default template, no matter what is the real capacity of the drive. You can see the real capacity only in DE when you make a new task.
- datasalvage
Roman_TS wrote:Source of the post Passport ID in Utility means nothing. It always shows you the default template, no matter what is the real capacity of the drive. You can see the real capacity only in DE when you make a new task.
thank you Roman! but the guide is not clear and i still get Invalid FW mode 5 (0) when i select the loader! should i keep shorted ? should i check on SAFE MODE?
Here is the guide about correct loader uploading:
https://blog.acelab.eu.com/pc-3000-ssd- ... t-xt2.html
If your internal drive firmware 100% compatible with the loader, but you got some issues with the final drive initialization - ask your customer about the story of this drive. Probably SSD was formatted, or customer already tried to update FW by himself.
- datasalvage
Roman_TS wrote:Here is the guide about correct loader uploading:
The guide you gave me doesnt work properly! the utility finds the loader but it doesnt work.....
Loader uploading
MPISP code name......................... : U0916A0 FBiCS5_06 (XT2); U0915A(N)
Seed table reading
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0004); ECC error
Completed
Firmware version (Internal)............. : V0111A0 FBiCS5_08
V0111A0 FBiCS5_08 (XT2); V0107A(N)...... : Ok
V0111A0 FBiCS5_08 (XT2); Q0209(D)....... : Ok
SSD status:
Operation aborted
Make sure that all NAND chips IDs are reading fine. There could be a hardware problem with this SSD.
Also, you can try to check neighbour loaders with similar V01XXXX FBiCS5_08 family.
