Drive WDC WD60EFRX-68L0BN1
Family Rembrndt
Drive shows up with no Serial no
Firmware no info
Capacity 0
System controller (SoC)................. : 88i1047F0 (5450)
ROM version............................. : 03.1TG
FlDir:.................................. : 20B
Phys - SA C:............................ : 256
H:...................................... : 1/0
S:...................................... : 4 960
UA C:................................... : N/D
Family:................................. : Rembrndt
Src..................................... : ATA2
Mode:................................... : Normal
HDD State:.............................. : Idle(0)
Drive shows busy
Techno mode key
Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT
System controller (SoC)................. : 88i1047F0 0x(5450)
ROM Data size........................... : 1024 Kb
Modules directory address............... : 533 335
SA Access check in RAM.................. : Static module reading error Device Error Detected: "VSC ERR INV FUNC CODE REQ"
Module 02 access........................ : Blocked
SA SPT.................................. : 4960
SA Translator loading................... : Module ID 30 reading error: HDD Redynes timeout (10000)
ROM Modules:
Module 4F F/W version................... : Module ID 4F reading error: HDD Redynes timeout (10000)
Overlay F/W version..................... : 03.1TG
Servo F/W version....................... : 01.0L
Head Map Reading Error.................. : Module ID 0A reading error: HDD Redynes timeout (10000)
Power up log reading.................... : RAM Table reading error: HDD Redynes timeout (10000)
Service area:
SA dir reading (ID)..................... : Techno key error: unexpected error: HDD Redynes timeout (10000)
Configuration reading................... : Module ID 02 reading error: HDD Redynes timeout (10000)
DCM in module 47........................ : Module ID 47 reading error: HDD Redynes timeout (10000)
DCM in module 0A........................ : Module ID 0A reading error: HDD Redynes timeout (10000)
DCM in module 02........................ :
Techno ON............................... : Techno key error: unexpected error: HDD Redynes timeout (10000)
Please let me know how we can get this drive fixed
WDC WD60EFRX-68L0BN1 VSC ERR INV FUNC CODE REQ"
- Paulfromsurrey
Paul Patil
PC Plus Computing
Data Recovery Services
Business IT Services and Computer Repair Services
https://pcpluscomputing.com/services/Da ... -Services/
PC Plus Computing
- Paulfromsurrey
Re: WDC WD60EFRX-68L0BN1 VSC ERR INV FUNC CODE REQ"
I found this file you think this will work to upload corrupted or misssing modular
https://files.hddguru.com/download/PC-3 ... irection=1
WDC WD60EFRX-68L0BN1-82-00A82-WD-WX11DC6RD93L.rar
Paul Patil
PC Plus Computing
PC Plus Computing
