New SED unlock for SpyGlass 3 bricking ROM
MrAnderson
Postby MrAnderson » 22.12.22, 05:25
I've read the ROM on two separate Spyglass 3 drives and unlocked using the new updated PC3K. After writing the modified ROM it becomes bricked. Attempting to ERASE and rewrite the original ROM with the same chip is no longer possible as it's now DEAD. I must use a donor ROM to proceed. What is the correct process for unlocking SpyGlass 3 drives without using an unlocked PCB?
I have two cases that I would like to work with module 190 issues using updated methods from the new release. I'd like to work off the original unlocked PCB converted to SATA by direct wire.
Thank you
Mr. Anderson
TriStateData.com
MrAnderson
Re: New SED unlock for SpyGlass 3 bricking ROM
Postby MrAnderson » 27.01.23, 04:00
The new update solved the issue. Thank you
Mr. Anderson
TriStateData.com
Return to “WD USB”
