overflow defect list WD Topic is solved
roham
Postby roham » 15.05.22, 07:00
hi
I did physical test and then add defect list into P list shows error overflow defect list
please guide me how to resolve it.
WD3200BEVT-11ZCT0
roozbeh
Re: overflow defect list WD  Topic is solved
Postby roozbeh » 25.05.22, 17:17
you should resize p-list or moudle 33 size in bigger size
roham
Postby roham » 18.06.22, 08:41
How should I do this?
Are the instructions explained somewhere?
Thank you for writing its URL.
roham
Postby roham » 16.07.22, 06:02
roozbeh wrote:Source of the post you should resize p-list or moudle 33 size in bigger size
roozbeh
Postby roozbeh » 27.08.22, 19:12
in work in service area you can resize module 33 and change the address
