SEAGATE 1TB HDD - SIM Error 1002 LBA 0000000000045D8C FD FCFFF3FF RW Error 44440080 PowerState = IDLE1
DRCSL
Postby DRCSL » 02.03.21, 13:06
Please some one help to me solve this hard disk problem. ? :|
find attachment picture.
RW Error 44440080
PowerState = IDLE1
Re: SEAGATE 1TB HDD - SIM Error 1002 LBA 0000000000045D8C FD FCFFF3FF RW Error 44440080 PowerState = IDLE1
Postby AJ2008 » 06.05.21, 18:18
did you solve this yet?
sigmaalv
Postby sigmaalv » 04.11.21, 12:27
i have same problem here
SimError - Remaining in BootFW
00001002Perform a double download without a power cycle
osity
Postby osity » 11.03.22, 20:12
No one ever found out what this is?
"SimError - Remaining in BootFW
00001002Perform a double download without a power cycle"
My guess, the indication of 1002 seems to point to NRG list or P list issue.
Postby DataMedics » 12.03.22, 22:06
osity wrote:Source of the post
Usually, that error is the result of a non-original PCB or non-original ROM. Check if the customer already tried a PCB swap.
DRCSL
Postby DRCSL » 26.04.22, 08:14
Received one more case like same error, anyone found solution for this ?
EC:0x43110081
Postby DataMedics » 27.04.22, 23:20
Like I said last time. It's almost always because it's not the original PCB / ROM
gterry
Postby gterry » 04.05.22, 20:56
I too am having a similar problem, I found that it wasn't the original PCB though and asked the user for the original one. He still had it and I verified the serial number once I attached it. However, Im still getting that error as well??? Anyone have a solution for this? Thanks, Glen
amlan007
Postby amlan007 » 09.09.23, 22:14
SIM Error 1002. its means the p list damaged or corrupted. also there is a way to fix this issue. in my dfl , there is one click to fix 1002 error. but after fixing the error will gone, but recovery speed is very low.
