I have 2060 810012 C type PCB which C port has a problem so drive powering up issue , now i need to solder SATA power cables to the 2060 810012 C type PCB . Anyone can help me to locate the GND and power pins location in PCB ?
Power pins to solder
- firdousnet
- d_d_recovery
- User
Re: Power pins to solder
Always best to test with a MM to make sure.
Power red, ground yellow.
- firdousnet
Not powering up
Not powering up
- d_d_recovery
- User
- firdousnet
No, still when I plug with USB cable drive powering up and not stable, so pcb not dead. Anything else to do to power up other than GND power solder? Have you tried to solder for C type PCB before?
- d_d_recovery
- User
You can wire up the SATA connections and then power the drive up by the USB connector.
- firdousnet
The problem is with USB connector power not stable continually so need stable power.
- d_d_recovery
- User
Did you use a Multimeter to test the points I marked?
Can you send a picture of exactly what you have done so far.
Users browsing this forum: Bing [Bot] and 6 guests
