Hello Everyone,
I have this HGST HTS541010A7E630, 1TB, (Z5K1000-1000) I was able to ID it correctly, but couldn't load the family in Utility, I looked everywhere for supported family but couldn't get to load the Utility.
I this Drive not supported by PC3000 UDMA-E ? Or am I getting something wrong ??
Please Help...
HGST HTS541010A7E630 Not Supported ??
Re: HGST HTS541010A7E630 Not Supported ??
IS it password locked?
Hello Bankole,
You can use HTS5450A7 family. Select it manually in Hitachi ARM utility.
Ok. Thanks, that works.
When using the 5450A7 tech mode for the 5410A7 the RAM head map editing function does not work correctly - it reports incorrect values in field.
E.g. rather than reporting "00 01 02 03 FF etc" it reports "20 00 E8 03 E3 78 05 04 0A 00". It appears not to be interpreting the area in the NV-RAM correctly.
J
J
avalanche, Correct Heads map is located by another Offset, please check here viewtopic.php?f=161&p=32454#p32454
Sergey_TS wrote:Source of the post viewtopic.php?f=161&p=32454#p32454
Sergey ,
Would you folks be correcting this in next update and adding support ?
Amarbir, I have no such info at the moment. Need to wait a bit
Hi Friends
Good day..
Did any got update for this issue awaiting for your support
hts541010a7e630
Model : HGST HTS541010A7E630
Serial : S0E001SSH2HHHK
Firmware : SE0OA4H0
Capacity : 0 MB ()
Head Map
20 01 E8 03 E3 78 05 04 01 00
Need Solution
Firmware : SE0OA4H0
Capacity : 0 MB ()
Head Map
Need Solution
Best regards,
Vijayan MBA
Raminfotech Data Recovery
call 7092114411/22
sky:raminfotech.vijayan
whatup:9841983643 / 46
Vijayan MBA
call 7092114411/22
