ST2000LM007 Update Mask
Dataman
Postby Dataman » 01.10.18, 18:14
Anybody help :shock:
Boot 0x80M
QB
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
(POR) Recover Secondary MCMT Opened Recovered
Common path start quit now Out:
InitiateMarkPendingReallocateRequest for disc_lba: 001D52347F CHS: 00001626.03.014C!
DSC PASS
InitiateMarkPendingReallocateRequest for disc_lba: 001D523481 CHS: 00001626.03.014E!
InitiateMarkPendingReallocateRequest for disc_lba: 001D525621 CHS: 0000163B.03.00CC!
InitiateMarkPendingReallocateRequest for disc_lba: 001D525623 CHS: 0000163B.03.00CE!
MSP213
(MC POR Duration): 0000000B45
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
Update Mask - 000000008C668E58 - 00000008 - 00
Update Mask - 000000008C668E60 - 00000008 - 00
Update Mask - 000000008C668E68 - 00000008 - 00
Update Mask - 000000008C668E70 - 00000008 - 00
Update Mask - 000000008C668E78 - 00000008 - 00
Update Mask - 000000008C668E80 - 00000008 - 00
Update Mask - 000000008C668E88 - 00000008 - 00
Update Mask - 000000008C668E90 - 00000008 - 00
This goes on and on for quite awhile:
Then
Starting LBA of RW Request=00118CD071 Length=00001A36
ProcessRWError -Read- at LBA 00118CD67C Sense Code=43160080
Common path start quit now ProcessRC: 00000000,00000000ReadContinuous: 118CD67C,0000024CTotalEntries:0002 XfrLen:024CUnrecovSectorCount:0002,0001NumUDEs: 00000002,00000001Failed: 40000087Out:
RECOV Servo Op=0395 Resp=0005
SP Regen FAIL
SPRegen [0000|43160080] @LBA=0x118CD67C
Setup currentretry count Out: [PRA]!
ProcessRWError -Read- at LBA 00118CD68F Sense Code=43160080
SP Regen FAIL
SPRegen [0000|43160080] @LBA=0x118CD68F
ProcessRWError -Read- at LBA 00118CD6B9 Sense Code=43160080
SP Regen FAIL
SPRegen [0000|43160080] @LBA=0x118CD6B9
Update Mask - 000000008C66B910 - 00000008 - 00
Update Mask - 000000008C66B918 - 00000008 - 00
Update Mask - 000000008C66B920 - 00000008 - 00
ProcessRWError -Read- at LBA 00118CD729 Sense Code=43160080
Then seems to repeat itself.
gterry
Re: ST2000LM007 Update Mask
Postby gterry » 14.12.21, 19:19
Bump for solution, I have the same issue.
msurgeon
Postby msurgeon » 18.12.21, 22:06
I assume you were not able to get to F3 prompt after hitting ctrl-z. Short the read channel so you can get to F3>T prompt. This will take some patience and good timing. Hit ctrl-z a couple times while shorting. You may have to let a long string of messages scroll by before you get to the prompt. Once you have the prompt read the last 32 commands to see where the error(s) are. Good idea to start by unchecking SMP flags in file 93.
Paulfromsurrey
Postby Paulfromsurrey » 06.02.25, 19:19
You found any solution for this I have the drive with same issue
Paul Patil
PC Plus Computing
Data Recovery Services
Business IT Services and Computer Repair Services
https://pcpluscomputing.com/services/Da ... -Services/
Users browsing this forum: Bing [Bot] and 7 guests
