Does WD Green SSD on Sandisk 20-82-00469-2 controller is NOT supported at this time via PC3000 SSD???
WD Green SSD
Re: WD Green SSD
Hello. Full list of supported SSD you can find below:
https://blog.acelab.eu.com/pc-3000- ... dated.html
WD GREEN is not supported for now.
- recuperodatos.com
Re: WD Green SSD
Hello Roman,
From what I currently see. This SSD is still unsupported.
It's right?
Bets Regards
Adrian
RecuperoDatos.com
It's right?
Bets Regards
Adrian
RecuperoDatos.com
Re: WD Green SSD
WD GREEN might be based on SM2258XT and on native Sandisk 82-00469. We can work only with SM2258XT modification at this moment.
Re: WD Green SSD
Roman_TS wrote:Source of the post WD GREEN might be based on SM2258XT and on native Sandisk 82-00469. We can work only with SM2258XT modification at this moment.
I would like to add here that OLDER ver. of WD Green is SM2258XT (2018) and the NEWER is Sandisk 20-82-00469-2 (early 2021)
Re: WD Green SSD
einstein9 wrote:I would like to add here that OLDER ver. of WD Green is SM2258XT (2018) and the NEWER is Sandisk 20-82-00469-2 (early 2021)
Both modifications on SM2258XT and Sandisk 20-82-0469 were produced and sell at the same time. There is no "older" or "never" versions. The main topic post was published at 2018, and Tweety already get a Sandisk modification.
- crashpcberlin
Re: WD Green SSD
Hello Roman,
the SanDisk Modification seems to be still unsuported, right?
Any plans when supporting these drives?
Re: WD Green SSD
We research it, probably a solution will appear in the nearest future.
