this hdd has a password from Lenovo mini pc it's like a SED of Seagate hdd.
hdd surface scan is very good condition .
SA read also good
anyone know how to fix this hdd issue?
CONFIGURATION GENERAL INFORMATION:
Device type......................................................... : Fixed device and/or controller
Device interface.................................................... : SATA (SATA Rev 2.6)
SATA Gen1 Signaling Speed (1.5Gb/s)................................. : [YES]
SATA Gen2 Signaling Speed (3.0Gb/s)................................. : [YES]
Rotation Rate....................................................... : 7200
Main data
Model............................................................... : HGST HTS725050A7E635 OPAL
Serial number....................................................... : TF655BWH2YZ3JR
Firmware............................................................ : GH26B8Y0
WWN................................................................. : 5000CCA77EE9CED0
Current Logical Parameters
Cylinders........................................................... : 16 383 16 383
Heads............................................................... : 16 16
Sectors............................................................. : 63 63
Capacity............................................................ : 16 514 064 sect. 7.87 GB
Capacity available in LBA Mode...................................... : 268 435 455 sect. 128 GB
Capacity available in LBA 48 Mode................................... : 976 773 168 sect. 465.76 GB
Security system
password set........................................................ : [NO]
HDD Locked.......................................................... : [NO]
HDD Frozen.......................................................... : [NO]
wrong password count exceeded....................................... : [NO]
security erase support.............................................. : [NO]
security level...................................................... : High
Capabilities
Standby timer values supported...................................... : [YES]
IORDY supported..................................................... : [YES]
IORDY disabled...................................................... : [YES]
LBA supported....................................................... : [YES]
DMA supported....................................................... : [YES]
PIO MODE
PIO MODE 3 Support.................................................. : [YES]
PIO MODE 4 Support.................................................. : [YES]
Available DMA Mode
Multiword DMA Mode 0................................................ : [YES]
Multiword DMA Mode 1................................................ : [YES]
Multiword DMA Mode 2................................................ : [YES] Selected
Active UDMA/33 modes
Ultra DMA/33 Mode 0................................................. : [YES]
Ultra DMA/33 Mode 1................................................. : [YES]
Ultra DMA/33 Mode 2................................................. : [YES]
Ultra DMA/33 Mode 3................................................. : [YES]
Ultra DMA/33 Mode 4................................................. : [YES]
Ultra DMA/33 Mode 5................................................. : [YES]
Ultra DMA/33 Mode 6................................................. : [YES]
Timing
Minimal multiword DMA cycle time.................................... : 120 ns
Recommended multiword DMA cycle time................................ : 120 ns
Minimal multiword PIO cycle time w/o stream control................. : 120 ns
Minimal multiword PIO cycle time with IORDY......................... : 120 ns
Supported standards
ATA - 3............................................................. : [YES]
ATA/ATAPI - 4....................................................... : [YES]
ATA/ATAPI - 5....................................................... : [YES]
ATA/ATAPI - 6....................................................... : [YES]
ATA/ATAPI - 7....................................................... : [YES]
ATA8-ACS............................................................ : [YES]
POWER MANAGEMENT
Mandatory power manement............................................ : [YES] Enabled
Power up standby.................................................... : [YES]
Advanced power manement............................................. : [YES] Enabled
Advanced power manement value....................................... : 16512
AUTOMATIC Acoustic Management
Feature set......................................................... : Not supported
Current value....................................................... : 0
Vendor recomended value............................................. : 0
Supported Command Sets
NOP................................................................. : Not supported
READ BUFFER......................................................... : Supported Enabled
WRITE BUFFER........................................................ : Supported Enabled
Host Protected Area feature set..................................... : Supported Enabled
DEVICE RESET command................................................ : Not supported
SERVICE interrupt................................................... : Not supported
Release interrupt................................................... : Not supported
Look-ahead.......................................................... : Supported Enabled
Write cache......................................................... : Supported Enabled
PACKET Command feature set.......................................... : Not supported
Power Management feature set........................................ : Supported Enabled
Removable Media feature set......................................... : Not supported
Security Mode feature set........................................... : Not supported
SMART feature set................................................... : Supported Enabled
FLUSH CACHE command................................................. : Supported Enabled
Device Configuration Overlay feature set............................ : Supported Enabled
SET MAX security extension.......................................... : Supported
SET FEATURES subcommand required to spinup after power-up........... : [YES] Enabled
Power-Up In Standby feature set..................................... : Supported
Removable Media Status Notification feature set..................... : Not supported
DOWNLOAD MICROCODE.................................................. : Supported Enabled
Trusted Computing feature set....................................... : Supported
Device Sector Info
Multiple logical sectors per physical sector........................ : [YES]
Logical Sector Longer than 256 Words................................ : [NO]
Logical sectors per physical sector................................. : 8
Alignment of logical blocks within a larger physical block.......... : 0
Words per Logical Sector............................................ : 256 512 b
HGST HTS725050A7E635 OPAL Sectors write error it's like a SED
- Abdurrahim.sopon
- Attachments
Abdur rahim sopon
Dhaka-1205 Bangladesh
mobile:01912-881685
skype:rahim3720
mail:Rahim@datarecoverybd.com
www.datarecoverybd.com
mobile:01912-881685
skype:rahim3720
