ST2000LM007-1R8174 sectors show $...m..mo.L.D..; Topic is solved
Abdurrahim.sopon
Postby Abdurrahim.sopon » 04.10.21, 11:18
I have a hdd with many sectors show ($...m..mo.L.D..; )
have any solution for this issue ?
Abdur rahim sopon
Dhaka-1205 Bangladesh
mobile:01912-881685
skype:rahim3720
mail:Rahim@datarecoverybd.com
www.datarecoverybd.com
lcoughey
Re: ST2000LM007-1R8174 sectors show $...m..mo.L.D..;  Topic is solved
Postby lcoughey » 05.10.21, 22:25
If there is a lot, change heads. If there is a small amount, you might be able to re-read those sectors.
Abdurrahim.sopon
Postby Abdurrahim.sopon » 08.10.21, 08:27
lot of sectors
Abdur rahim sopon
mobile:01912-881685
skype:rahim3720
Tawfeek
Postby Tawfeek » 10.10.21, 20:51
i faced same , chang heads and it act the same . i'm sure it's not heads
Filipp_TS
Postby Filipp_TS » 21.10.21, 19:47
That might be head(s) issue - one or few head(s) can't pass internal heads test after power on or/and not compatible (if current heads are from the donor drive)
also (less possible) that could be an issue related to corrupted/damaged MCMT
