New family of M11 drives?
Paradog84
Postby Paradog84 » 17.09.21, 13:52
Has anyone come across any of these newer M11 Seagates?
Fam ID................... : 0xCF, (Fam_CF)
SN....................... : WCJ5LPCX
Servo FW rev code........ : 0xB1BF
Max head................. : 9
Seek mode................ : 2000
Flags.................... : 0A09
Head vendor.............. : default
Preamp type.............. : 0000
Heads polarity........... : 00 00 00 00 00 00 00 00 00 00
Logical head map......... : 00 01 02 03 04 05 06 07 08 09
Phys head maps........... : 00 00 00 00 00 00 00 00 00 00
ROM is unreadable via terminal - we had to remove it a manually dump in external programmer (2Mb)
Tech Unlock patch results in LED:0x000000BB FAddr:0x00004300 instantly from power on (drive does spin but never becomes ready)
Loading the ROM into Seagate Utility - we are able to modify the Logical Head map, import adaptives etc, but not Tech patch
Doomer
Re: New family of M11 drives?
Postby Doomer » 17.09.21, 16:18
That would be M15 family
Paradog84
Postby Paradog84 » 20.09.21, 18:10
Thank you for confirming...
I'm looking at one of these drives now, we have a working drive (potential donor) to play with, but not looking good so far (tech patch unsuccessful)
Doomer
Postby Doomer » 20.09.21, 18:18
These drives are locked on the Boot ROM level (that's why you can't read/write the flash through the terminal) and old patch won't work
Paradog84
Postby Paradog84 » 21.09.21, 12:12
I see - thanks again Doomer for the info :thumbup:
