Pinout Sandisk Extreme Pro SDXC II 128 GB
edbrandt
Postby edbrandt » 11.08.21, 14:11
Hello there
Does anyone know pinout for a Sandisk Extreme Pro SDXC II 128 GB. Unfortunately it is not supported by PC-3000.
Also, if someone does; do you also know the internal structure - if it can be solved in PC3K after dump is read.
Attached is some pictures. I have not sanded the card yet (in case I can't proceed with the card), but the connectors can be seen through the coating.
Also.. I have a Sandisk Extreme Pro SDXC 128 GB from the same customer. Dump is read, but the controller is a Sandisk 82-00410A which currently is unsupported by PC3K due to partial data encryption. Anyone familiar with this controller?
I need to solve one of these card as the customer unfortunately formatted both cards (master and backup) in his Sony A7 Camera, and from what I understand the only way to recover files then is to perform a raw recovery from dump.
Thank you in advance
Best regards, Espen
arvika
Re: Pinout Sandisk Extreme Pro SDXC II 128 GB
Postby arvika » 16.08.21, 21:28
edbrandt
Postby edbrandt » 17.08.21, 23:31
Thanks. Do you know pinout, and if it can be solved with PC3K?
-Espen
arvika
Postby arvika » 18.08.21, 20:09
Yes I have. I do not know if it possible solve by PC3K.
Multi-COM
Postby Multi-COM » 18.08.21, 21:52
This pinout is supported by MR SP09 adapter - https://multi-recovery.com/subpages/MRSP09.php
Boguslaw Rzepka
http://multi-com.eu
