Hello, can someone check Database of Memory Chips?
Is 453E9AB3 present? If YES please send me a Screenshot of Parameter.
THANKS
who can check Chip-ID 453E9AB3 in actual Version
Re: who can check Chip-ID 453E9AB3 in actual Version
Hello. What is the full ID of this chip? You send just the first part. There should be also a second
If it's a 7E720000 then it's supported, but I'm seriously doubt that it would be possible to solve this case without latest release with Translator support.
Hello Roman,
bad news - had some hope...
The second part is: 7E720D0E
It's supported, but modern Sandisk cases - are a real nightmare. We can work with them and in most cases we are able to get the best possible result. But the latest software update is required - it contains new Sandisk assembling methods + new XORs for Sandisk cases.
