ST500LT012-9WS142-188 - CfwDiscCode Not Loaded
drdoc
Postby drdoc » 08.07.16, 18:48
I have a
st500lt012 I have bought 2 drives that appear to be good matches. As a test I pu the customers board on the donors to guage if it attempts to come ready.
If it locks onto the servo then chances are good that the heads have read compatibility.
customers drive does 3 big head sweeps and spins down with this message. There are no signs of crashing.
*** UPDATE ace says its rom corruption - anyone have s solution
Rst 0x10M
SPINUP FAILED
ExecuteSpinRequest
op=0100 resp=0003
op=0100 resp=0003
LED:000000BC FAddr:00007A43
CfwDiscCode Not Loaded: 0002B4E0
patient===========
Model : ST500LT012-9WS142-188
Serial : S0V0G7D0
Firmware : 0001SDM1
Capacity : 465.76 GB (976 773 168)
PN: 9WS142-188
SITE:WU <<<<<< DIFFERENT
DATE:13065
dom:08/2012 <<<
pcb:100696152 REV A <<<<
PreampType: D0 05
if I ^Z on powerup I can get terminal and
YARRABP LM93_1_1 SERVO256 RAP22 4k VBAR STD Mobil
Product FamilyId: 5F, MemberId: 0A
HDA SN: S0V0G7D0, RPM: 5408, Wedges: 100, Heads: 2, Lbas: 7470C06, PreampType: D0 05
PCBA SN: 0000K301CRBR, Controller: LUXORM93_1_1(FFFF)(FF-FF-FF-FF), Channel: MARVELL_9311, PowerAsic: MCKINLEY MOBILE PLUS Rev 15, BufferBytes: 1000000
Package Version: YA418A.SDM1.CA0663., Package P/N: ---------, Package Builder ID: 84,
Package Build Date: 05/28/2012, Package Build Time: 17:16:22, Package CFW Version: YA41.SDM1.00457396.8400,
Package SFW1 Version: A823, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 06630001, CustomerRel: 0001, Changelist: 00457396, ProdType: YA41.SDM1, Date: 05/28/2012, Time: 171622, UserId: 00080603
Servo FW Rev: A487
RAP FW Implementation Key: 16, Format Rev: 5D02, Contents Rev: 40 06 04 05
Features:
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 enabled
donor1
Serial : W0VG6KHZ
Firmware : 0001SDM1
PN: 9WS142-188
DATE:14153
SITE:WU
dom:10/2013
pcb:100696152 REV C
PreampType: D0 57
F3 T>
HDA SN: W0VG6KHZ, RPM: 5408, Wedges: 100, Heads: 2, Lbas: 7470C06, PreampType: D0 57
PCBA SN: 0000K4129MPB, Controller: LUXORM93_1_1(FFFF)(FF-FF-FF-FF), Channel: MARVELL_9311, PowerAsic: MCKINLEY MOBILE PLUS Rev 8C, BufferBytes: 1000000
Package Version: YA418A.SDM1.CA0713.0001SDM1, Package P/N: ---------, Package Builder ID: 84,
Package Build Date: 07/02/2013, Package Build Time: 11:56:10, Package CFW Version: YA41.SDM1.00585251.8400,
Controller FW Rev: 07130001, CustomerRel: 0001, Changelist: 00585251, ProdType: YA41.SDM1, Date: 07/02/2013, Time: 115610, UserId: 00080603
Servo FW Rev: A498
RAP FW Implementation Key: 16, Format Rev: 5D02, Contents Rev: 40 12 04 05
Features:
- IOEDC enabled
- IOECC enabled
- LTTC-UDR2 disabled
DONOR2============
Serial : S0V5NEFN
Firmware : 0001SDM1
PN: 9WS142-188
SITE:SU
DATE:13375
dom:03/2013 <<<
pcb:100696152 REV C <<<<
PreampType: B0 54
F3 T>
HDA SN: S0V5NEFN, RPM: 5408, Wedges: 100, Heads: 2, Lbas: 7470C06, PreampType: B0 54
PCBA SN: 0000M336AH6E, Controller: LUXORM93_1_1(FFFF)(FF-FF-FF-FF), Channel: MARVELL_9311, PowerAsic: MCKINLEY MOBILE PLUS Rev 8C, BufferBytes: 1000000
Package Version: YA418A.SDM1.CA0697.0001SDM1, Package P/N: ---------, Package Builder ID: 84,
Package Build Date: 11/09/2012, Package Build Time: 11:39:40, Package CFW Version: YA41.SDM1.00506459.8400,
Controller FW Rev: 06970001, CustomerRel: 0001, Changelist: 00506459, ProdType: YA41.SDM1, Date: 11/09/2012, Time: 113940, UserId: 00080603
Servo FW Rev: A494
Features:
- IOEDC enabled
- IOECC enabled
- LTTC-UDR2 enabled
skype: wayne_horner
Alandata Data Recovery
Re: ST500LT012-9WS142-188 - CfwDiscCode Not Loaded
Postby Amarbir[CDR-Labs] » 14.04.21, 10:14
Today i had this case ,I mapped 00 00 in ROM and i was able To Access Side 00 and Head 00 ,This means its not a ROM issue their diagnostic is wrong then
osity
Postby osity » 23.09.22, 00:21
drdoc,
If your patient HSA has at least 1 working head, you can reinstall it and it should initialize without this CFW error giving you access to the SA and user area.
With this model, I've also seen that using the native ROM, but one from saved from a different date, will result in the drive staying spinning.
It seems like an overlay issue and/or head computability issue but I can't say for sure.
Did you ever resolve the issue?
