I've there a ST1500LM006 HN-M151RAD that I thought was BSY, but after about 40/50 sec comes in Ready State.
Then again 4/5min for reading modules table from SA... I'm now backuping HDD Ressources, but it will probabely take the day, and I even don't know at this stage if I'll have sector access, and speed copy.
Does anyone had a similar case ? Any advice welcome.
EDIT : Many ERR/UNC while copying modules, but all seems to be OK until now
EDIT2 : 25min for heads map, now copying head 3 -> quick and fine
edit again : head3 100%. head4 work in progress. Will continue head by head and if a head is to slow will try to get used map.
Last edit : head 3 and head 5 100%, head4 and head 2 50% quick then slow, without errors. head1 and head0 : slow from beggining, reverse also, very few unreadable sectors but some are not read because of delay. When OFF/ON and wait for about 65s (changed in dataextractor also) secrtor become readable. I managed to read filesystem strcutre, and create submab, now reading file by file but veeeeery slow. Will take weeks.
So... still hoping for solution or ideas, thank you for your help.
