Need LDR for the following: Thanks in advance!
ROM:
ROM Data size........................... : 1024 Kb
Modules directory address............... : 675 852
SA Access check in RAM.................. : Static module reading error Device Error Detected: "VSC ERR INV FUNC CODE REQ"
SA Translator loading................... : No S/A SPT info avalable
ROM Modules:
ROM version............................. : 06.0JH
ROM F/W version......................... : Module ID 4F reading error Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Overlay F/W version..................... : 06.0JH
Servo F/W version....................... : 03.6B
WD20SPZX-22UAA7T0 resources needed -- Charger fam.
Re: WD20SPZX-22UAA7T0 resources needed -- Charger fam.
What will you do with resources? Save ROM and open 4F from inside it and check what the error is with it. Maybe you can repair this without donor resources anyway
