NEWBIE - Western Digital 3.5" Spins and powers off
efx
Postby efx » 17.02.21, 23:56
Western Digital drive spins and then stops spinning. Unable to read Drive ID. Drive shows up as tornado 2R in kernel mode.
Techno mode key
Cyl Count............................... : 128
ROM Modules:
ROM version............................. : 58.A8D
ROM F/W version......................... : 005800A8
Overlay F/W version..................... : 58.A8D
Servo F/W version....................... : 01.0M
Heads map............................... : 2,3,4,5,6,7
d_d_recovery
Re: NEWBIE - Western Digital 3.5" Spins and powers off
Postby d_d_recovery » 18.02.21, 00:04
More than likely head failure.
Did the client tell you what happened to the dive?
Has it been dropped?
Postby AJ2008 » 18.02.21, 10:00
You have options for RAM head map edit which may help, but if spindle shuts down there is almost certainly some head or heads issue and you should likely check for internal damage (i.e. twisted heads, media damage etc) as repeated attempts to operate can cause further issues.
efx
Postby efx » 20.02.21, 00:53
d_d_recovery wrote:Source of the post More than likely head failure.
Customer said drive randomly died.
efx
AJ2008 wrote:Source of the post You have options for RAM head map edit which may help, but if spindle shuts down there is almost certainly some head or heads issue and you should likely check for internal damage (i.e. twisted heads, media damage etc) as repeated attempts to operate can cause further issues.
Thank you will look for donor drive.
