I have a WD20SDRW case with a damaged head assembly.
I replaced the heads, the USB PCB did not move.
I connected to PC3000 - read MFT, started data recovery.
I have recovered the data - and new for me ... in the folders where the recovered data is located, some data is damaged and some data is functional (No directory! Problem)
I do not understand why...
An example on the screenshots
WD20SDRW - 11VUUSO - Problem
Re: WD20SDRW - 11VUUSO - Problem
Maybe the SMR translator is damaged, or some head is weak and can not read good. Need to use an unlocked SATA PCB to do that.
When i try to read data with unlocked PCB - data is crypted new V2 encryption, that for now PC3k is not support.
Make a backup, then return USB PCB back, open the same task in Data Extractor and try to build head map according saved modules.
