Hello, the terminal show me:
Bad CRC Seg:0x05
Bad CRC Seg:0x24Bogus ISR
CPSR = 0x200000D2
R14 = 0x00001C6C
stays on BSY state.... Anyone can help me-.... thanks
Seagate ST31000524AS stays BSY
Re: Seagate ST31000524AS stays BSY
does it power ok and show solid BSY register?
Hello, based on terminal report drive has corrupted/damaged/not native ROM.
Read it and compare S/N with S?N on drive's lable - it should be the same.
If S/N is native like Filipp suggests you check then import adaptives like RAP CAP SAP IAP into similar donor ROM and program to hdd
