Self Encrypt V2 in new palmer
Tawfeek
Postby Tawfeek » 12.12.20, 18:38
i have WDC WD10SDSW-11AGTS1 USB . convert it to Unlocked Sata 8000066. it work healthy . all sectors can read with data but can't find any files even in row . i try the 2 option in Decrypt data box with same result
P.S :- usb with bad Broken connector
P.S :_ i should select family as palmer manually
is there some thing missing here
Doomer
Re: Self Encrypt V2 in new palmer
Postby Doomer » 12.12.20, 21:33
This drive decrypts through CPU. Thus you'd need original CPU to decrypt the data.
Tawfeek
Postby Tawfeek » 13.12.20, 12:48
Doomer wrote:Source of the post This drive decrypts through CPU. Thus you'd need original CPU to decrypt the data.
thanks Boss , i even try another usb pcb from very close donor with same Encrypted result
Doomer
Postby Doomer » 14.12.20, 18:22
Tawfeek wrote:Source of the post
Yeah, the key is unique, unfortunately.
Abdurrahim.sopon
Postby Abdurrahim.sopon » 08.01.21, 17:15
did you try same pcb in your cloned drive ?
Abdur rahim sopon
Dhaka-1205 Bangladesh
mobile:01912-881685
skype:rahim3720
mail:Rahim@datarecoverybd.com
www.datarecoverybd.com
FTWOTECHNOLOGY
Postby FTWOTECHNOLOGY » 14.04.26, 08:44
is anybody has firmware for WD10SDSW-11AGTS0
ROM version............................. : 00.0CM
Module 4F F/W version................... : 0000000C
Overlay F/W version..................... : 00.0CM
Servo F/W version....................... : 03.73
please share as soon as possible
italyassistance
Postby italyassistance » 18.04.26, 09:57
FTWOTECHNOLOGY wrote:Source of the post is anybody has firmware for WD10SDSW-11AGTS0
https://firmware.hddsurgery.com/
Return to “WD USB”
