I have WDC WD20EZRZ-00Z5HB0 2TB.
The WDC Marvel Util recognizes this HDD with Serial, Model and correct capacity.
Techno mode key
RAM:
SA SPT.................................. : 1740
ROM:
Modules directory address............... : 330 212
ROM Modules:
ROM version............................. : 15.ABC
ROM F/W version......................... : 001500AB
Overlay F/W version..................... : 15.ACC
Servo F/W version....................... : 05.67
Heads map............................... : 0,1,4,5
Service area:
Permanent overlay....................... : Loaded
But gives ABR error on reading any sector shows me "Techno OFF error Device Error Detected: "Unknown error code: 4344".
I tested Heads and all are Health.
All modules in both copy 0 and copy 1 are ok.
I even changed PCB for sure but I have same problem.
I did Translator Regeneration ( use P-list Only) but i have same problem and i haven't access to user data area.
Please help me ..
Thanks a lot
WD20EZRZ-00Z5HB0
Re: WD20EZRZ-00Z5HB0
thanks for your reply.
I solved it myself
I solved it myself
I have same problem. Could you notice how did you solved this problem? tnx
aryadiba, the issue may be in Slow Responding. Also need to try RAM head map changing for system heads http://blog.acelab.eu.com/ram-head-map- ... -case.html
