PNY SDHC micro SD - need pinout
edbrandt
Postby edbrandt » 14.10.20, 11:12
Anyone know type and pinout for this card?
It's a micro SD card inside a 32 GB PNY SDHC SD card.
Couldn't find it in the monolith database
-Espen
SGdata
Re: PNY SDHC micro SD - need pinout
Postby SGdata » 14.10.20, 12:06
Did you see how damaged the traces are? I doubt that correct pinout will help here. Card needs to be fixed first.
edbrandt
Postby edbrandt » 14.10.20, 13:37
@SGdata Please explain, where do you see damaged traces?
SGdata
Postby SGdata » 14.10.20, 14:12
here
edbrandt
Postby edbrandt » 14.10.20, 14:19
@SGdata Ok, I just haven't sanded all the way out before taking the picture.
SGdata
Postby SGdata » 14.10.20, 14:37
Looks like you sanded too much :)
d_d_recovery
Postby d_d_recovery » 14.10.20, 18:24
SGdata wrote:Source of the post here
As the OP says, this is just where the conformal coating has not been removed.
SGdata
Postby SGdata » 14.10.20, 21:49
Doubt it, look at the pins. But it would be good for the data that i was wrong.
arvika
Postby arvika » 14.10.20, 23:03
http://odzyskiwanie-danych.com.pl/image ... arvika.jpg
SGdata, there is no important signals.
edbrandt, we have pinout if you want outsource the case.
edbrandt
Postby edbrandt » 15.10.20, 09:07
@arvika I was thinking you might have :) I'll send you a PM. Thanks
Multi-COM
Postby Multi-COM » 26.10.20, 21:49
@edbrandt: This card is very popular ... we got adpater for it - check at https://multi-recovery.com/subpages/MRV04.php
Boguslaw Rzepka
http://multi-com.eu
