Hi guys, I need help to solve this problem as soon as I start the terminal. module 348 I can read with errors, 28 and 35 are accessing. Initially, there was the MCMT table is corrupted error, in a topic they suggested running F,,22, after I was able to read more SYS files, the MCMT error disappeared and Error Sim error 3005 appeared, without accessing the data area with UNC error.
What would be the next step? Did I make a mistake using F ,, 22?
Any help would be appreciated.
Boot 0x80M
Tech Unlock Handshake: 0xE634F569
Reply:
QB
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
(P) SATA Reset
RAW OFF
SIM Error 3005 LBA 0000000000005D33 FD FC378093
RW Error 00000080
DOS:0 Scan Unit
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
ABORT!
OpCode = 00000024
SenseCode = 03310003
ReadyStatusFlags = 0002A1A1
ABORT!
OpCode = 00000024
Unrecoverable Read Verify Error Reported
ResetAbortDst
ResetAbortDST
ResetAbortDST
(S) SATA Reset
ST2000LM007 Sim error 3005 - UNC error
- Emerson Santos
Re: ST2000LM007 Sim error 3005 - UNC error
F,,22 set SMP flags by default and doesn't related to any other firmware structures.
Based on provided terminal report now drive has problem with 93 system file (maybe something issue with other firmware structures) as result Translator is not uploaded in RAM.
Necessary find all problem system files and fix them.
